Mowing Mower deck will not stay on set height.
   / Mower deck will not stay on set height. #1
7derubis11
Johnstown, PA
KUBOTA 2620
I have a B2620--60" deck and when I set my cutting height for mowing in does not stay. The dealer replace the adjustment (which is a pick of junk) it work for about a couple of months. Help?????
   / Mower deck will not stay on set height. #2
I had a 2620 with the 54" mmm. It just dropped to the ground one day while mowing. My dealer sent the cam to me, that adjusts the mowing height, and I replaced it. That did not fix the problem.
I then took the 2620 to the dealer and let him fix it. They fixed and it stayed fixed until I sold it.
I had a BX25 that I cut a lot of grass with and it had a mmm. I never had a problem with the mmm.
I think the set up on the b2620 is a bad idea.
There is too much weight on that cam and it did not hold up for me.:2cents:
   / Mower deck will not stay on set height. #3
I've seen mine (60 " MMM) drop a notch or two without me noticing it until I came around again. Seems like this usually happens on rough ground. Now I take look at the setting periodically. I do set the anti-scalp wheels about 1/2 inch above wherever the cutting height is set.
SKIL SAW MITER SAW (A58374)
SKIL SAW MITER SAW...
More info coming soon! (A55851)
More info coming...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
21" X 75" X 58" METAL SHELF (A58374)
21" X 75" X 58"...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
WACKER NEUSON RTSC3 TRENCH COMPACTOR (A52709)
WACKER NEUSON...
