Mowing mower decks
   / mower decks #1
Mike N.
I own a Kubota G1900 Garden Tractor with a 60" deck. This deck cuts very nicely but it tends to bounce alot while mowing due to being a Floating type mower. There are caster wheels on the back and anti scalp wheels on the front. Will the bouncing wear out the mowerdeck driveshaft or is this the way it is designed to operate? I had a suspended mower on my last tractor, could someone explain further. Thanks
   / mower decks #2
Also have a G1900S with same deck,if your deck has the helper springs located on the back edge of mower,adjust these springs as tight as you can,without regard to what the chart shows.This will help your deck "float" a little better over a not so perfect lawn.Also,play with the tire pressure a little,the lower pressure will help the over-all ride of the mower quite a bit.Hope this helps,good luck.
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
1459 (A57192)
1459 (A57192)
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
40 (A52708)
40 (A52708)
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
2021 Deere 333G (A53317)
2021 Deere 333G...
