Mower PTO Cuts Out Intermitently
   / Mower PTO Cuts Out Intermitently
Steelstring,
I found the location, and I found the relay; but the relay I have is a HFV6 012ZS-TR(555).
I looked up the specs on the one you linked to, and this one fits the same socket. I guess it could be the same problem even if it's not the same part number.
   / Mower PTO Cuts Out Intermitently #12
I'm guessing that Cub Cadet simply sources whatever relay is cheapest at the time of manufacturing, so there may be several different brands of the same relay with different part numbers. Pull the relay off of your tractor and compare the diagram on the side (if it has one) to the one on the website. I bet they are the same. For $5, give it a try.
That's what I had figured. I sent the guy an e-mail to get the relay coming. I'm with you. For $5 it will at least answer the question if that's the problem or not. It beats the $30 for the switch.
Good luck! Let us know how it works out!
It didn't work. I am VERY impressed with the service and shipping time for that relay. It came today, but when I installed it I got the same problem.
I tried D7E's fix, though; and it worked...
D7E said:
I have exactly the same problem with mine , But works fine when you press the safetey button ?
I know of others that have had trouble too and have had the safetey thing changed .
Any more info about what "safety thing" others have changed? I'm happy to report to the owner that he can use his mower, but I'd like to get the right part and fix it right for him.
2018 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52705)
2018 CATERPILLAR...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2019 CATERPILLAR 315FL CR EXCAVATOR (A52705)
2019 CATERPILLAR...
