Mower Width
   / Mower Width #1
belezar
NC
MF 245, 2635
I am looking to buy a discbine to cut about 175 acres for hay. I want to get as big as possible and still get a good cut. The ground is fairly flat, but definitely has some roll and unevenness in places. Is 9' too big? I am worried about scalping and poor cutting. Many thanks in advance for your opinion.
   / Mower Width #2
How many pto hp is your tractor? Our 85 hp tractor is a good match for the 9 foot 10 inch or however many inch it is. It pulls it fine when the grass is tender. We hook it to a 145 hp tractor when the grass gets dry and tough in the summer.
   / Mower Width
I will get the tractor to fit the mower. With that amount of acreage, I want to be as efficient as possible (within reason). I was looking at a 85-90 hp tractor as well as a 120 hp. I don't want to pull 2 rigs, but do want to know if there are problems with width from a cutting standpoint.
   / Mower Width #4
I cut some very uneven ground with ours with no complaints. I certainly wouldnt want to go smaller. You will be pleased with cutter you mentioned. The 85-90 hp will do fine also. I just use a bigger tractor in the summer because I dont like to slow down a gear. Some people say I cut too fast, so if your not cutting @ 9mph you probaly wont have to slow down when the grass gets dry and tough to cut.
   / Mower Width
I also looked at an 11' 6" Kuhn pull behind this weekend. Any thoughts on that? Requires less HP, and would get a lot done quickly.
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
2018 JOHN DEERE 410L BACKHOE (A52705)
2018 JOHN DEERE...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A55787)
2018 JCB Truss Jib...
2013 TAKEUCHI TB180FR EXCAVATOR (A52705)
2013 TAKEUCHI...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2018 Ford F-150 (A55788)
2018 Ford F-150...
