Mower Will Not Start
   / Mower Will Not Start
Have you pulled the bowl on the carb to make sure it is not plugged up or full of water?
Think most of the Craftsmen mowers are running magneto ignition so mag must be ungrounded with power to carb solenoid to run.
David Kb7uns
Thank You,
Checked this and no water but is pumping gas very strongly.
Jerry
Thank You,
Yes, it is . Has power at all 7 electric plug ins on the switch. Power going in and out. Could it be from the kill switch at the Coils?
Jerry
   / Mower Will Not Start #13
Thank You,
I don't know if there is a low oil pressure cut off. Embarrassed to say, I don't even know what that is! Wouldn't know how to find it and I read the owners manual, but it did not have anything in it about the cut off. Would it really be unusual for both coils to go bad at that exact time together?
Jerry
It's unusual for the coils to go bad in the first place. They tend to be overworked due to owners not changing spark plugs as recommended. Overworking coils for long periods will eventually kill them due to heat breaking down the individual wires' insulators.
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2015 DODGE RAM...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
