mowing in reverse
   / mowing in reverse #31
JD X300 Reverse PTO override switch operational modification:
(1) Open hood
(2) Unplug wiring connector/PTO-RIP switch {under dash}
(3) Examine closely and locate: Gray 370B and Green 301 wires.
(4) Using about 2" insulated wire,you provide, remove 3/16" insulation from both ends.
(5) Insert 2" jumper wire to bottom of wire connector. Insert jump: 370B Gray to 301 Green.
DO NOT CUT ANY HARNESS WIRING. May void JD warranty!!!
I did not solder my connections. Jumper easily removed when future JD warranty service work is needed.
(6) Zip-tie{you supply} jumper wire securely to wiring harness.
(7) Reconnect wire harness to PTO-RIP switch and close hood.
DONE!!!
Happy reverse mowing!!!
   / mowing in reverse #32
I took a piece a wood, trimmed it on the grinder till it fits under the pull up switch/blade engagement switch, works good, a 2 minute job.
No wires to fiddle with under the dash.:thumbsup:
   / mowing in reverse #33
I did my 355D and X748 with jumper wires. My 355D went in for warranty service and I told the service manager I had bypassed RIO and the seat and asked if I should restrore it. He said "no problem, we don't care if you bypassed them". They are a big Ag dealer.
When I traded the 355D on the 748 I did restore their function.
2015 Chevrolet Ambulance (A52377)
2015 Chevrolet...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
1265 (A50490)
1265 (A50490)
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2004 Ford F-550 4x4 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2004 Ford F-550...
