Mowing Stripes
   / Mowing Stripes #1
Anonymous Poster
Epic Contributor
Well, I finally figured it out! Duh!!!
A few days after I mow. I always get these tall "stripes" of grass.
It finally dawned on me. I have a 48" rotary mower behind my trusty B8200. But, with the wide turf tires, I track about 52" So, when I mow, I knock down a "stripe" of grass that then doesn't go under the mower and get cut.
I've been wanting R4's, which are narrower. Anybody wanna trade Turf for R4's in N. Calif? Oh well, it was worth a try...
   / Mowing Stripes #2
Hi Robert. My 12.8 x 16 R4's actually have a wider footprint that the 13.6 x 16 turfs. There is probably the same rubber on the road on pavement, however, the R4's are less rounded-off than the turfs were. Also I have learned that on my B8200 with one implement I have to be careful not to raise the 3pt too high or the treads whack the stabilizers. I'm going to have a welder modify the implement. Anyway... I put a 72" finish mower on this spring and your B8200 will handle it. I finally found a 6 footer that does not exceed the 3pt capacity to lift it. BefCo C30 RD6 weighing in at 420 (+/-). You've got to get some R4's... what a profound difference from the turfs! And they also are smooth on the street, which is important for me, as I drive a mile each week on the road to cut my Dad's grass.
   / Mowing Stripes #3
Yeah, also if you have a 3-blade finish mower with some old worn out blades, you will eventually get two strips of grass left on each pass... that's harder to deal with though. Just try overlapping your pass by the with of a front wheel or so.
<font color=blue>>></font color=blue>Muhammad
<font color=blue>Forum Master</font color=blue>
   / Mowing Stripes #4
I have been doing the overlap thing, which in turn gives me effectively about a 36" mow.
Oh how I want the R4's! But, it's $$$'s away... /w3tcompact/icons/frown.gif
RobertN in Shingle Springs Calif
   / Mowing Stripes #5
Yes, I forgot to mention that little detail, that you'll lose 1/4 of your cutting width. /w3tcompact/icons/wink.gif
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
Cat TH407C Telehandler (A51039)
Cat TH407C...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
