Mowing Mowing with a compact tractor
   / Mowing with a compact tractor #1
Anonymous Poster
Epic Contributor
I will be purchasing a 30hp 4wd tractor (probably a JD 4310 ehydro) with FEL. I will need to cut a "lawn area" of about 3 acres. My ultimate plans call for a zero radius mower but with the house being built, etc, I can only enjoy so many toys. My question concerns using a belly mower versus a 3 point finishing mower. Does anyone have any opinions? Thanks.
   / Mowing with a compact tractor #2
I've got a 60" MMM. My lawn is not completely in yet, but I can mow my 2 ac. in 1 hour. My opinion about the RFM and my experience with other 3PH attachments is that they might be more difficult to swing into tight spaces than a belly mower. Someday, mowing will make up most of the work I do with my tractor and I plan to have a lot of landscaping, so that is important to me. I don't have any other mowing machines planned for my future though, so that would probably make a difference. The biggest advantage to the RFM is the ease of taking it on and off. I don't know how the JD system works, but I can switch between my Loader and Mower deck in about 15min.
Just my $.02
Wbender
There a many threads on this site discussing the benefits and costs of both mmm and rfm. Run a search and start reading. I would say every possible opinion and aspect of these two mowers has been explained on the threads you can find here. Once your decide on mmm or rfm you can start to figure out if side or rear discharge meets your needs. After doing the research I ordered a rfm rear discharge in a 72" size for my B2910 to be delivered tomorrow I might add! /forums/images/graemlins/laugh.gif
I have about three open acres to mow so the rfm seemed to be the right choice in my case. I think you will find that the guys that have a lot of trees and obstacles opt for the mmm while the guys with open areas seem to go for the rmm. What ever works for you. Good luck.
   / Mowing with a compact tractor #4
Well, much as I love my 3010, I use my little John Deere 18HP lawn tractor from my grass. Its only about 2 acres, but it gets done real quick with the lawn tractor. Its easier on the grass because it weighs less, and can scoot under trees, get close to the house, and so on.
Of course for tall grass it would bog down, but when thats been a problem I simply mow with 'deck up'.
Just my opinion, but a good lawn tractor is easier on the pocketbook and probably better suited to your job, if all you intend on doing is cutting a few acres of lawn.
Naturally, if you see other uses, even snow clearing, a CUT may be a better choice.
You could, maybe, look into renting or borrowing to try it out.
   / Mowing with a compact tractor #5
Have u looked at any of the NH CUT w/ SS.
My 35D w/ 84" MMM turns almost like a zero turn.
It will turn right back for the next pass.
Taking the mower off is a couple minute job and 5 or so putting on.
   / Mowing with a compact tractor #6
wbender,
I didn't purchase my tractor primarily for mowing but eventually I will be mosing a few acres. I bought my tractor used and it didn't come with the belly mower. I ended up purchasing a RFM (First Choice 60"). This decision was based mostly on money as the RFM is about half the price but also I'd heard that taking the MMM on and off can be quite a pain. The RFM cuts perfectly, adjusts easily, and works well in areas where the "grass" couldn't really be considered lawn. The belly mower might work equally well in those areas but I'm not sure.
Now with all that being said. If I had to do it all over again I think I would have looked very hard for the stock MMM for my machine. I don't think I'd get a better cut but I think mowing would be far simpler. I don't take my loader off when mowing so when I'm tooling around my tractor is pretty long with the loader and the RFM on. My 2 cents says if you are buying a new machine go ahead and get the MMM. Good luck
   / Mowing with a compact tractor #7
wbender,
I guess that I am spoiled. I have two Kubotas; one with a mid-mower and one with a rear-mower. I use them both on a regular basis (or should I say that my wife and I use the two tractors...). Here are my opinions:
Maintenance: With regards to maintenance, the rear mower is much easier when tasks such as blade sharpening is required. Mid-mowers typically require you to remove the deck to access the blades.
R&R: With regards to installation and removal of the mower, the rear-mower used to be extrememly easier, but with modern mid-mower designs, the difference has been reduced, but the rear mower is still easier to deal with.
Storage: When storing the tractor with mower attached, the mid-mower has a decisive edge as it takes MUCH less garage space to store.
Availability: Rear mowers are readily available, and can be assumed to stay that way. Mid-mowers are typically custom designed to the tractor; therefore, chances are that at some time in the future the mid-mower that is available today may no longer be available.
Cost: The custom built mid-mower is almost double the cost of a rear-mower.
Issues with Mowing...
Maneuverability: The mid-mower is much more maneuverable than the rear mower. Plan to let someone with lower operator abilities mow?
Breathing Dust & Debris: Have allergies? The rear mower offers the advantage of having the discharge chute located much further away from the operator relative to the mid-mower. A rear discharge mower is even better in this regard.
Hard-to-Reach areas: The rear mower allows the operator to put the mower in areas that would be impossible for mid-mowers. For example, I'll use my rear-mower to mow over the edge of a bank, over the edge of a river, or under tree limbs.
Stability: I feel much more comfortable mowing questionable slopes using the mid-mower than with the rear-mower. If I mow down a slope with my 3-point mower and am not perpendicular to the slope, the mower will have a tendancy to push the tractor sideways as it obviously wants to travel down the hill faster than the tractor is moving.
Bottom Line: I think that answers to the "which is better" arguement varies greatly based upon the answers to the following questions:
(1) What is the percentage of time is the tractor used for mowing?
(2) Does the area to be mowed dictate one type over the other?
(3) Do you frequently use the tractor for other tasks that requires the mower to be removed?
The majority of my tractor's operating hours (80%?) are used for mowing. In general, I actually like mowing with the mid-mower best, when the area to be mowed allows. This statement assumes that I am comparing a side-discharge mid-mower with a side-discharge rear-mower. Since I like rear-discharge mowers better than side-discharge mowers, I usually end up mowing with my 72" rear discharge 3-point mower.
Good Luck,
Kelvin
   / Mowing with a compact tractor #8
Kelvin, excellent post. You covered the subject well. Most of us have a tendency to "sell" our preferences, but your post is very informative.
Mower choice is pretty much a matter of going through a checklist like yours, and seeing what characteristics are more important to the individual. I had a tractor with a MMM, and now have two with RFM's. When I bought the last RFM (Landpride AT2560), the big decision was between side and rear discharge. My Mom-in-law has a 60" mowing machine with RD, and it always leaves windrows between the blades where the grass blows out. I didn't want to end up with that scenario.
Some people prefer the RD so they can trim along sidewalks/flower beds/etc travelling in either direction. I kinda like being able to use the mower to gather leaves and such using the side discharge as an overgrown leaf blower................chim
   / Mowing with a compact tractor #9
Well said Kelvin. One thing I've wondered about and maybe this will impact wbender's decision too is this...
I've got 2 acres of almost lawn and 1 acres of old farm field that's not too rough but has lots of rocks. I've mowed the area with my MMM up but I wonder if the rear mower would be any better for rough cutting until this is converted to lawn also? I can see most big rocks before I hit them, but occasionaly I've hit the top of a few. It seems I might be able to raise the RFM a little higher than the MMM.
   / Mowing with a compact tractor #10
I just purchased a lawn tractor to cut the grass around the house and will be buying a new RFM for my 4300 to cut the rest of our eight acres. I tried cutting the area around the house with the 4300 with a rear mower and just was not happy. I have the R4 tires and the tight turns were a problem even out of 4wd. I bought a twenty-five hp 42 inch cut tractor and it does a much better job.
I can just get in places that the 4300 just could not go. My goal is to set the landscape up so everything can be cut in the seated position.
66in Dual Cylinder Grapple Bucket Skid Steer Attachment (A44571)
66in Dual Cylinder...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A46877)
Toyota 6FGU25...
Kubota 1140 (A44391)
NEW 2017 Xtreme Green Utility Vehicle 72V w/Locking Tool Drawers, Tow Hitch, LED Work Station (A46877)
NEW 2017 Xtreme...
2021 Ford Explorer AWD SUV (A44572)
2021 Ford Explorer...
24ft x 28ft Metal Building (A44391)
24ft x 28ft Metal...
