MS Access question
   / MS Access question #11
If you use the print command on the "file/menu" bar instead of the print button command in the field, does it work or do you still get the 30 or 40 pages?
   / MS Access question #12
Here's a quick 'n dirty Access97 (sorry, that's as modern as I've got!) database that uses an autoexec macro to open a form that has a pick list to choose from. Clicking on the button beside each name print previews a report with just the data for that name and none of the others.
The secret is building a query underneath the report that has the criterion that the Name must equal the currently chosen Name on the form, if that makes any sense. If you don't apply some kind of limiting statement like that, as the others have said, the report just goes out and gets the entire list.
Hope this helps a bit. Good luck! /forums/images/graemlins/smile.gif
P.S. You'll have to unzip the file first!
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
ELECTRIC CENTRIFUGAL PUMP (A58216)
ELECTRIC...
Lot 251- LINCOLN MARINE STYLE WELDER SHIELD ARC SAE-400, DIESEL, HOURS SHOWING: 2,814 (A59213)
Lot 251- LINCOLN...
Giyi Excavator Pallet Forks (A57149)
Giyi Excavator...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
