MT180D hydraulics
   / MT180D hydraulics #1
PILOON
Super Star Member
North of Mtl,Que,Can (Ste Adele)
MT180D
On my MT180 , under the seat left side, there is the hydraulic connection for the 3PT mechanism.
Sandwiched there is an accessory block to take hydraulics to a loader valve or whatever.
Since I have a second pump installed for the FEL that block is unused most of the time except when I attach an accessory via the 2 short hoses and quick connect fittings.
Not knowing any better I always leave the fittings connected to each other to make a loop (like always open circuit) to return pressure back to supply.
The question is: could I plug these 2 ports or have permanantly mounted quick connects neatly mounted on a bracket rather than the now messy coiled hoses that I leave connected.
Or otherwise stated is this block an open circuit device.
I was always afraid that if plugged pressure would build up and that I be reyling on bypass valves to prevent damage.
   / MT180D hydraulics #2
I expect Bill or Len will cruise in and answer this. If not try the mitsubishi/satoh club on yahoo. Wish I could answer myself.
   / MT180D hydraulics #3
I think we have already talked about this but for the benefit of others you must keep these hoses connected so as to create a loop. Otherwise pressure will build up and blow the cover on the side. I learned this one the hard way. If you want to remove the hoses, remove the block and reinstall the cover. Bill
SKID STEER ATTACHMENT PACKER (A58214)
SKID STEER...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
2018 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2018 KOMATSU...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
