MT372 Clutch Issue and Repair
   / MT372 Clutch Issue and Repair #11
Update on the Release Bearing shaft, I was able to get it pulled today by welding a heavy washer to the release shaft and getting a bearing puller behind it with a slide hammer attached to puller and with 3 pops and she's out, Just gotta get the right tools. Now just have to grind the welds polish it up slap some never seize on it and then start checking the clutch. Shoo that was a little more then I expected.
   / MT372 Clutch Issue and Repair #12
Sounds like you're getting closer. Keep us posted and good luck.
   / MT372 Clutch Issue and Repair #13
So when this happened you had a stuck release bearing? Did the tractor and pto have no movement at all? I have been looking for a solution to my case 275 that was working and now has no gears or ranges and no live pto any longer. It all just suddenly quit. And it had done this before then started working but not this time.
Survey Kit (A53316)
Survey Kit (A53316)
golf cart (A55787)
golf cart (A55787)
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
2017 Hitachi ZX245USLC-6N (A47477)
2017 Hitachi...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A55788)
2003 Ford F-250...
