Muffler in the dirt? Will it work?
   / Muffler in the dirt? Will it work? #11
Since when does seeds need CO2? I thought they need oxygen and water to start growing. That's why you don't deep plow all the time. It brings old seed (weeds) back up to the top. :confused:
   / Muffler in the dirt? Will it work? #12
Found this on the net:
CHARACTERISTICS OF DIESEL EXHAUST
Diesel fuel is a mixture of many different hydrocarbon molecules. The combustion, both complete and incomplete, of diesel fuel forms a complex mixture of hundreds of organic and inorganic compounds in the gas and particle phases.
Gaseous Components of Diesel Exhaust:
Carbon dioxide
Oxygen
Nitrogen
Water vapor
Carbon monoxide
Nitrogen compounds
Sulfur compounds
Low-molecular-weight hydrocarbons
Toxicologically Relevant Gaseous Components:
Aldehydes (formaldehyde, acetaldehyde, acrolein) :eek:
Benzene :eek:
1,3-butadiene :eek:
Polycyclic aromatic hydrocarbons (PAHs)
Nitro-PAHs
Particulate Component of Diesel Exhaust (Diesel Particulate Matter - DPM):
Elemental carbon
Adsorbed organic compounds
Small amounts of sulfate, nitrate, metals, and other trace elements
Toxicologically Relevant Compounds Adsorbed on DPM surfaces:
(PAHs and their derivatives are adsorbed on the surface DPM
(Figure 1)
Polycyclic Aromatic Hydrocarbons
Nitro-PAHs
Oxidized PAH Derivatives
(For in-depth analysis of these DE components, go to this link: http://oaspub.epa.gov/eims/eimscomm.getfile?p_download_id=36255 )
The components of diesel exhaust (DE) emissions are a public concern for the following reasons:
* Emissions from diesel engines include over 40 substances that are listed by the EPA as hazardous air pollutants.
* Components of DE contain potential cancer causing substances such as arsenic, benzene, formaldehyde, nickel, and PAHs. :eek:,:eek:,:eek:,:eek:,:eek: !
* The diesel particulate matter (DPM) is very small (90% are less than 1um by mass), making DPM easy to respire into the deep lung.
* DPM has hundreds of chemicals adsorbed to their surfaces, including many known or suspected carcinogens. :eek: !
* There are many irritants and toxic chemicals in the gaseous phase of DE.
* Oxides of nitrogen, component of urban smog, are in the gaseous phase of DE.
* There is a likelihood that people in both ambient and occupational settings can be exposed to DE.
* DE has the potential to cause adverse health effects including cancer, pulmonary and cardiovascular diseases.
* Studies show workers exposed to higher levels of DE are more likely to develop lung cancer.
* In 1990, the state of California identified DE as a chemical known to cause cancer.
* The International Agency for Research on Cancer has concluded that DE probably causes cancer in humans.
* The EPA has proposed classifying DE as a probable human carcinogen. :eek:
Despite all of these concerns, it is difficult to understand the nature of DE and to measure the exposures from DE and it壮 health effects with certainty. DE is only one of various sources of particulate matter and gaseous air pollution in the atmosphere and workplace. Though the evidence is persuasive that DE has the potential to cause adverse health effects, there are uncertainties. There are gaps and assumptions in the data about human exposures to DE. An assessment of how the physical and chemical nature of past exposures compare to current exposures is not possible since available data are not sufficient. Also, much is not known about DE toxicity and carcinogenicity in humans. DE exposure could have synergistic or additive behaviors occurring with exposures to other air pollutants. More definitive data and more research is needed to improve our understanding of the nature of DE, DE exposure, and potential human health effects to DE. And finally, it is difficult to assess DE exposure because of improvements in engine design, fuel grade, and emissions technology relating to the nature of DE.
So it seems that, at the very least, there are some things in DE (Diesel Exhaust) that are beneficial to the soil and plants.
And there are obviously some things in DE that are harmful to the soil, plants and animals also.
But if you follow the argument that all (or at least most) of the stuff we put into air ends up back in ground (via rain, wind, etc.) then why not accelerate and focus the process where it will do the most good.
I don't know how closely this relates, but the areas of my lawn where I spread the ashes from the fireplace are much greener and healthier than the untreated areas. Thus, in my mind, combustion bi-products must have some beneficial properties.
   / Muffler in the dirt? Will it work? #14
I think that's it in a nut shell.
I suspect the environmental movement is the only big gainer in this.
I would be surprised if there is much of an effect on the plants, considering the size of the land, compared to the volume of exhaust.
The guy that farms the 40 behind me, pulls a rig about 20 feet wide. That's a long way to spread the exhaust. Its not anhydrous ammonia.
   / Muffler in the dirt? Will it work? #15
The only thing I see is that if it puts carbon in the ground it will raise the PH of the soil. . . .
Actually, Deerkid, it would LOWER the pH! Particulate carbon (unburned/black soot) would be pH neutral, but any CO2 that remained in the soil would tend to combine with moisture to form a very dilute H2CO3 - carbonic acid/soda water, lowering pH. All those unburned hydrocarbon products would just be 'crud' (a HIGHLY technical term) left in the soil. As a (retired) chemical engineer, I'd have to see quite a bit of research data before I'd sign on:confused:
   / Muffler in the dirt? Will it work? #16
Not sure if appropriate or not, but a little hijack. They are finding Atrazine in lakes around the north woods miles from farm land. They are thinking maybe it is being picked up by wind and evaporation and returned as rain on distant lake in amounts that are not harmful (according to some standard) but still measuable.
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53472)
NEW 2025 Load...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
