Mulch around trees, yes or no?
   / Mulch around trees, yes or no? #11
Before wife had me pull the bushes I used to mulch with a weed blocking fabric underneath. Saved a lot of weed whacking and herbicide. When I tried mulching w/o the fabric it took a lot more mulch to block the weeds, but by the end of the summer they still came through.
   / Mulch around trees, yes or no? #12
Do you have recommendation as what type of mulch to avoid with certain tree ? or it doesn't really make a difference ?
No, I haven't personally heard of any compatibility problems but I only use what is supplied in bulk specifically for landscape use. I suppose its possible to have problems if you're using what a tree service grinds up if the trees were carrying pests, disease or toxins but I think the risk would be pretty low and I don't know of anything specifically to look out for. Cedar is toxic to lots of things so I wouldn't use it in areas where animals would be exposed to it at length.
   / Mulch around trees, yes or no? #13
A few years ago I switched to cardboard under the mulch, it seems to work as good if not better than landscape cloth. And it's free and reduces my recycling pile......
   / Mulch around trees, yes or no? #14
Last year I planted 4 spruce trees that were each in 1 gallon pots.
I put a 24" recycled rubber tree ring around each one and a bushel or so of homemade wood chips around the tree ring. When they get a little bigger I'll remove the rings.
I also put a chicken-wire fence around each of the trees to keep the small wildlife away and a large tomato cage around it to keep the deer away.
Looking good so far.
I also planted an 8' tall oak as a memorial tree several years ago and mulched it in a 6' radius. It's about 15' tall now and all the fencing was removed.
   / Mulch around trees, yes or no? #15
I tried cardboard but unless I tore it up into strips or made a lot of holes in it the soil underneath did not get water from rain.
   / Mulch around trees, yes or no? #16
If possible, I'd also try to avoid mulch from walnut trees. The juglone is bad: Black Walnut Tree Toxicity - What Plants Are Immune?
UNUSED FUTURE D680 56" HYD PILE HAMMER (A57193)
UNUSED FUTURE D680...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
204923 (A57192)
204923 (A57192)
Mailbox (A55853)
Mailbox (A55853)
2005 Military Trailer (A53424)
2005 Military...
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
