Must have tools
/ Must have tools #1
Barryh
Veteran Member
Harpers Ferry WV - Mountains of Shannondale
Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
Will be adding to my tool inventory.. Any advice on must have tools you guys have found need for .. Specif size, curved and or specialty size wrench's for in your PT garage.. As in removing motors, pumps hose's etc. Best place to order them online. I'm sure I'll need them eventually..
Thanks for our input..
/ Must have tools #2
FWIW I buy a lot of goody boxes at auctions that have tools in them and have got drawers full of them and a lot of name brand ones too. for specialty tools such as curved or twisted wrenchs I pull one of the no name ones out of the tool box and clamp it in the vise and bend it the way I want for the job I need to do.
/ Must have tools
Great idea of bending cheap wrenches never thought of that ...:cool:
/ Must have tools #5
I changed the fuel filter on my tractor last week and had a senior moment and didn't bleed the air out of it. I didn't want to pull the hood to get to the injector lines and I took an 11/16 cut a notch out of the box big enough to pass the injector line thru and bent it to the right about an inch down and inch right. it fit perfect between the manifold ports to loosen the injectors and tighten them. the wrench went into the tractor tool box
/ Must have tools
Nice ... :thumbsup:
/ Must have tools
>>>> Modifying cheap sockets and extensions makes special tools too, at a fraction of the cost. <<<<
Some useful ideas here .. :thumbsup:
/ Must have tools #8
Make life easy.
Get an electric impact wrench with 1/2" drive, sure air is best but that wants a hefty compressor with lots of CFM's.
(Just got one on sale for $50.00, Father day special)
Then shop garage sales and flea markets for sockets.
/ Must have tools #9
You need the wrench that fits the nut under the center pivot joint. It needs to be tightened periodically. Can't remember the size off-hand, but its a MUST, MUST!! (double must). :)
/ Must have tools #10
Big wrench for the Jesus nut, Strap Wrench for the oil filter, I have Crows Feet and angled wrench set. Large Wrench set (you are going to need big sizes as well as small). Big can be US but the Smalls you need both Domestic and Metric
Wrench Sets | MSCDirect.com
Crowfoot Socket Wrenches - Sockets and Bits - Grainger Industrial Supply
As noted as well, get an impact wrench, and get an extender.
Speaking of extenders, get a breaker bar. and then go buy a pipe to go over your breaker bar and extend it. Get a pipe that can go over a number of tools to get more extension.
PT has two issues, either the guy who put it together didn't tighten it enough or they over tightened it. Either way, loose loose for you.
/ Must have tools #11
I have a lot of mechanics tools. I usually have what I want, but there are two things I don't have that I often wished I had. One is a 3/4 drive ratchet set, both metric and english. I don't need it very often, probably once a year, but its on my wish list. I have one good set of taps and dies(for cutting threads). I wish it had bigger sizes and my set is english, I wish I had metric also. Same thing, I probably only need it once a year or less, but on my wish list.
/ Must have tools #12
25 or so years ago, I bought a standard 3/4" socket set from HF for $29. I liked it so much that I bought several more as gifts and a metric one for myself. It is still going strong. I must admit I was quite surprised because back then especially, most HF tools were pretty crappy. I also bought a crow's foot wrench set from either HF or Northern.
I won't swear to it but I am pretty sure that large wrench you need is 1 13/16". And I find a nice Rigid strap wrench is a necessity for tightening the hydraulic filter.
Ken
/ Must have tools #13
fi you can get Odd tools for a good price but buying for the sake of adding to your collection is not the most cost effective way, IMO,
I usually wait until I have a need, and then buy, for example I may buy a kit, say a kit of special sockets, or kit of torx, some times I buy only what I need, but start with your basics, 1/4", 3/8", 1/2" sockets, and two sets of box and open end wrench's, that basically cover your socket sizes,
depending on what one has one may only need metric now, but would think having SAE would be good as well, the thing about special tools is most of the time there limited to one brand or model, and the next years is some thing different,
adding U joint sockets, impact sockets, impact wrench, ( probably would not get a 3/4 or 1 inch drive sockets unless you have need for them, I would suggest 1/2 impact wrench first, and then a 3/8" and or a 3/8 ratchet wrench,
short wrenches, thin or tappet wrenches, ( I find various extensions, and socket adaptors, 1/2 to 3/8 and 3/8 to 1/4 ect, can be very handy),
I even have a set of 8 point sockets for square nuts, (not that many used any more but on pre 1960 machinery they can come in handy),
VOM meter, inductive ammeter for checking out put of alternators or the draw of starter, (some companies makes a small unit one lays over the wire), battery load tester,
/ Must have tools
Some great advice on here from everyone.
I have many tools in my garage but looking for specific ones for the Power Trac. I should have added I already have the large center nut wrench .. Thanks to everyone and thanks to Woodlandfarms for the links.. Will be adding an impact wrench and some of these crowfoot wrenches / sockets for the very tight space limitations of the PT tub /compartment.. I also noted some large 3/4 inch hex head nuts on my PT will be ordering some of those in socket form..
/ Must have tools #15
DON"T BUY OFF MY LINKS
Sorry, I was just referencing what they are. Not a good deal. Hunt around. Sorry for the confusion.
/ Must have tools
No confusion I understood.. I always shop around I appreciate the advise on the type of tools needed ..
/ Must have tools #17
Thats an awesome idea. So far, a specialty wrench I'm going to get is a oil filter socket for the FRAM XG4967 oil filter. I also hear its good to have a wrench for the hydraulic filter on these PT-425s that you can get some good leverage with, because Terry is telling owners to take it a full turn after snug.
/ Must have tools #19
Make sure your impact wrench can handle the torques you will need.
I just went through the process of
Change the fitting on my Lowes 200 ft lb rated impact wrench
String the airline to my truck
Try and undo the nuts (torqued to 150 ft lbs).
No workee :(
Apparently the 200 lbs wasn't really 200 lbs.
/ Must have tools #20
Size of your airlines and fittings can affect the torque (as can the pressure setting but I assume that was set correctly). I have switched to the high flow fittings for that reason.
Ken
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
Allis Chalmers 1200 Field Cultivator (A66408)
Allis Chalmers...
White Oak Boards (A65640)
White Oak Boards...
60in. Work Bench (A65640)
60in. Work Bench...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
