MX 5 slip clutch hardware question
   / MX 5 slip clutch hardware question #1
Dan Hunter
Platinum Member
Enid, OK
2012 John Deere 3720 eHydro
Does anyone know what the sizing is on the capscrew and lock nuts on the slipper clutch of an MX5? The operator's manual identifies them for a MX7 but not the MX5.
   / MX 5 slip clutch hardware question #2
JDparts should the capscrew as part number 19M7179 (see attachment) specs are
Specification
Weight 0.09 LBS 0.04 Kg
Thread Size 10.000 MM
Thread Pitch 1.500 MM
Length 50.000 MM
Thread Length 26.000 MM
Head Width 16.000 MM
Head Thickness 6.580 MM
Material or Grade 8.8
Finish B
The nut is part number M82222 specs are
Weight 0.02 LBS 0.01 Kg
Thickness 9.200 MM
Width Across Flats 14.865 MM
Wrenching Height 0.00 MM
Locking Element Type D
Material Grade 10
Finish B
I got the specs logging into JDparts and entering the part number
  • mx5slipclutch.pdf
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
Toro 3100D (A50324)
Toro 3100D (A50324)
Western Snow Plow with Brackets (A50515)
Western Snow Plow...
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
