mx 5100 remotes
   / mx 5100 remotes #11
candyman said:
orange toys,
what have you hooked to your remotes & how are they working.
cm
I've had no issues at all. I just have a top link hooked in right now and ill be adding a cylinder to a rear blade soon.
What kind of pics do you want? I thought I had everything posted already.
   / mx 5100 remotes #12
If the MX5100 is anything like my L5740 it should be a very easy install. I did mine in a couple of hours. Just be careful with the O-rings that they don't get out of place before things are bolted together.:thumbsup:
   / mx 5100 remotes #13
Check out purchasing the 3 factory Kubota valve kits and install them yourself. Then put an electric divert-er valve on one of the factory valves for the 4Th unit. Relatively quick, and makes for the cleanest install.
I would be sure to get at least one of the remotes with float position, you will want it for your tilt cylinder of the top and tilt kit. ;)
   / mx 5100 remotes
orange toys, i got the pix. thanks
mvr, what do you mean diverter valve, please xplain, i`m lost. when this is all said & done i`ll be getting the top & side units from you.
thanks, cm
   / mx 5100 remotes #15
The diverter valve switches the output from one of the spool valves to a different set of hoses/quick connects.
In other words, if you have a three spool valve and one diverter, you have enough outputs for 4 sets of remotes simply by switching the diverter to the alternate position. Keep in mind that you have to switch the diverter between the two sets of remotes, both won't work at the same time.
I think there are diverters that are capable of handling more than 1 set of connections, I haven't looked at them personally.
I may be wrong on this, but that's the way I understand it.
   / mx 5100 remotes #16
I have an MX5100 that I would like to add a set or two of rear remotes. Would anyone here have the Kubota kit number for the parts? Thanks!
Curtis
   / mx 5100 remotes #17
Curtis
Curtis,
Go to the Messick's web site and pull up the parts document for Kubota-MX5100DT-"OPTIONS" . It will list all the individual parts. I'm not sure what the "Kit" numbers are but if you call them, they'll be able to help.
HP
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52128)
1994 Thomas Built...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
2015 ISUZU NPR 16FT BOX TRUCK (A51219)
2015 ISUZU NPR...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
