MX5000 Stalls after warming up
   / MX5000 Stalls after warming up #1
dlaroche
Martinsville, IN
Kubota MX5000
When my tractor warms up it stops running. I have replaced the fuel filter, but the fuel will not completely stop flowing when the turnoff valve is closed. I am going out to bleed the system now. Hopefully this solves the problem.
   / MX5000 Stalls after warming up #2
Does it still stall if u removed fuel cap? I am thinking it might be not letting air into tank. Just a thought.
   / MX5000 Stalls after warming up #3
   / MX5000 Stalls after warming up #4
I second the gas in the diesel situation.
I poured 5 gals of gas in my L4400 in error one time.
Then added 5 gal of diesel, to make it all better.
The engine would start and run until the two fuels started mixing in the tank, then it would lose RPM's until it stalled.
Solution: drain and refill tank with fresh fuel, dump fuel filter. Once you get it running right, go mark your fuel cans. That is what caused my problem... ;-)
   / MX5000 Stalls after warming up #5
Anytime I've seen gas in a diesel it knocked like crazy, which was the first sign that something wasn't right.
It was gas in the fuel. Drained and refilled and it runs fine. Thanks much for the replys.
   / MX5000 Stalls after warming up #7
Glad you are up and running. It should not have hurt it this time but would not do that again.
   / MX5000 Stalls after warming up #8
I use the yellow cans for my diesel
Sent from my iPhone using TractorByNet
2016 CATERPILLAR 299D2 SKID STEER (A51242)
2016 CATERPILLAR...
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A51243)
2004 TRAILKING...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
