MX5100 fuel usage
/ MX5100 fuel usage #11
my kubota sipps fuel no matter what im doing with it.but you have to remember im used to dealing with bigger farm tractors.
/ MX5100 fuel usage #12
Yep, mine is off also. The good thing is I alway have more fuel than it shows.....
/ MX5100 fuel usage #13
I dont have a mx5100 but it was on my short list... my L5740 is a fuel hog too in my opionion comparing the same work to my old mf35 its about twice the fuel burn for same tasks. I'm disapointedto say the least.
/ MX5100 fuel usage #14
1-2 gallons an hour? Wow! Both my Kubotas are 2-3 hours per gallon and the old L3750 is a 5 cylinder and 3900 lb.
Gear drive here and usually not running over 2000 rpm. Could the high fuel usage of the MX5100 be a HST thing? Or do some of you have gear drive?
I ask because I'm going to replace the 3750 at some point with a larger machine.
/ MX5100 fuel usage #15
I don't care about it too much now that I know about the error, but yes, when you consider the amount of engineering that went into the engine, transmission, or even the loader geometry, you'd think they could get the fuel gauge to read correctly.
I'll bet if you look at your tank it is an irregular shape which makes getting a totally accurate reading from a float type sender almost impossible.
/ MX5100 fuel usage #16
I average 1-1.5 gallon per hour for overall usage. That includes everything from cutting grass and brush, pushing snow, moving dirt, grading, pulling logs, hauling firewood, pulling trailers etc...
I am rarely over 2k rpm unless running the pto. Mine is gear drive.
/ MX5100 fuel usage #17
Thanks for the info! The MX5100 gear drive is one I'm considering.
/ MX5100 fuel usage #18
The work that most folks do with a small tractor like the MX5100 of L5740 is really variable, so fuel consumption will vary.
When bush hogging, the grass isn't usually consistent thickness, when rototilling, there is generally a lot of stopping and starting, when doing loader work, it is generally not heavy load on the engine. It is no different than having an MPG range on a car. For $20 you can get a lot of work done.
/ MX5100 fuel usage #19
heres something that i just thought of.if you want to know what it cost to run or how meny gal of fuel you use do this.take the gal you use in a day an devide by hours worked.then times the cost of diesel to gal used in an hour.i usually dont worry about how much fuel i burn.
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
159116 (A60430)
159116 (A60430)
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
Deere 35G (A53317)
Deere 35G (A53317)
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
240156 (A56859)
240156 (A56859)
