MX6 Brush Hog Shakes Tractor?
   / MX6 Brush Hog Shakes Tractor? #31
go to deere parts online. You have to create an account with a name and a password but I don't remember that you have to give anything else.
   / MX6 Brush Hog Shakes Tractor? #32
I had something like that happen to me. I loaned out a brush hog and the guy bent the drive shaft. I told him not to try to cut down 5 foot tall brush in one swipe. I told him to set it high the first time and go in low gear about 2 miles per hour. Instead, he set it low and went about twice as fast as he should have. The drive shaft bent under the stress. He told me about it and took the drive shaft to get it fixed. If your friend that you loaned the brushhog is a decent person, he should bear the responsibility of getting it fixed. Period!
   / MX6 Brush Hog Shakes Tractor? #33
When I rebuilt the gearbox on my brush hog a few years ago I had to use a 20 ton press to remove the stump jumper from the shaft after removing it from the gearbox. When it came loose it shot out like a bullet, make sure to pad the area under the press so you won't have to file the threads like I did.
It was a Severs CY60.
   / MX6 Brush Hog Shakes Tractor? #34
ive notied the bigger the RC the more my tractor shakes...make sure the the RC is level and rev up engine speed more slowly...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55218)
2015 Ford F550...
