My Carryall Saga...
   / My Carryall Saga...
A piece of waterproof subflooring should work. It is expensive though and will eventually delaminate in the weather.
The 2x8 idea is worth consideration for long term durability.
Yeah, after reading on here, I'm planning to go with the 2x8's.
   / My Carryall Saga... #22
Does anyone know of some good online retailers to get the lynch pins and the top link pin from?
Any local tractor dealer will have the parts. TSC can be used but, of course, shipping is a factor. TSC has them in stock.
Hey CTF
I too was very interested in the carryall from TSC. I went to the local store where they had one. We tried numberous CAT 1 toplink pins and could not get one to fit (the toplink pin hole was too small). I decided not to buy the unit as I was concerned it might be defective so I am curious to see if the one you purchased has the correctly sized toplink pin hole. I don't know the width of a toplink pin off hand (I am sure someone one this site does) but you may want to measure to see if one will fit (or try one from another implement).
- Dana
I think a standard cat 1 toplink is 3/4". Don't have another implements to try...I'm going to get the pins soon...By the way: It's nice to see members from this area. :thumbsup:
Yes, I know, but I might not be able to get to one for a while, so ordering online would be the best option...
   / My Carryall Saga... #25
I am looking for a way to move a befco 9.5 ft mower around in the barn without. Always hooking it up to the tractor. Is tree any products avaliable that anyone has used like dolly wheels that I can put the mower on and push about the barn when I need to move the mower? thanks
Route66
   / My Carryall Saga... #26
I was thinking of either doing that or using a piece of plywood. Would that work?
Most any wood will work, however, the 2x8's will be much more durable and can take a licking and keep on ticking.
If you want to spend your money once...go with 2x8's.
I made the mistake of using 1x12 pine boards. I have found that the boards will crack and chip at the grain of the wood.
Definately use 2x8's. Pressure treated if you can afford it.
It is a good attachment to have. I have used mine for things I never thought I would. Like carrying an old porch floor to the burn pile.
Though a carryall is light in weight, I do find it to be a bugger to hook up to the 3pt. hitch. I'd rather hook up my snowblower.
   / My Carryall Saga... #27
Route66
There are lots of good ideas on TBN for just what you are looking for. Most are homemade and fit the implement involved perfectly. Do a search and you'll see.
   / My Carryall Saga... #28
Another thing you might consider is to just use pallets. You can nail a piece of plywood to the top and have a smooth, flat surface.
If you use 2x8s the Carryall will be tied up only for things you can carry on it.
With pallets you can have different things on each pallet, build them for special tasks (like firewood hauling), pre-load them for quick use later, etc. It is a much more flexible solution.
The pallets will eventually splinter and break so then you get another fresh pallet and use it until it is destroyed.
   / My Carryall Saga... #30
We don't use a carry all anymore, but for years we did and used pallets; worked great for us as we had them from a business.
Thanks! I am planning on going with the 2x8's...
How would you do this? I don't think there is enough clearance to use them like forks.
   / My Carryall Saga... #37
Most feed stores have tractor pins...and some auto parts stores also have them...
get carriage bolts to fasten your boards...don't drill the holes too big so the bolts spin....
If you have a hydraulic toplink...the carryall will double as a "dumping" platform...Honestly...without a HTL the carryall will not be nearly as useful...I've carried many things that needed to be tilted back to steady...I've also needed to tilt it up in the back to make it easy to slide a piece of equipment on...either one having to use a manual toplink would be a chore....IMO a HTL makes a carryall a much more dynamic attachment...
if you plan on painting it to match your tractor be sure to take all the stickers off and rub it with course steel wool...
We don't have a hydraulic toplink or a SCV so that's not an option...I'm not planning on painting it right now.
   / My Carryall Saga... #39
I would go with 5/4 pressure treated decking material. Over that span on the carry all it would cut down on added weight and be plenty durable for use.
Figure that a 2x8 is more than twice the amount of lumber as a 5/4 x 6 decking. Plus at the big box home improvement stores the decking will cost less per foot than the 2x8.
   / My Carryall Saga... #40
Interesting. I just get mine made, patterning it off of the TSC Countryline, and I noticed they rotated the top horizontal angle iron 45 degrees to get the toplink attachment point vertical. Either that or the way I fabricated my carry all is the new design.
Anyway, sounds like quite the adventure. Driving around ain't cheap anymore. I called my local TSC and asked them if they had something in stock a month ago and they had no clue what I was even talking about. They are not the same store as when they first opened, that's for sure. At least around here.
Bobcat A770 (A60462)
set of 4 tractor trailer tires Roadforce (A56438)
set of 4 tractor...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
