My CHEAP Tractor Weights @ 72.5 lbs Each for $7.68 :D
   / My CHEAP Tractor Weights @ 72.5 lbs Each for $7.68 :D #1
rgs03833
Haverhill, MA
MTD 660, 690 - John Deere 60, 70, 108, 2 of 111, 111h, STX38
Hey Guys....
Here are my Cheap Tractor Weights...
Final Weight about 72.5 lbs each and $4.42
Materials:
1. Concrete Block ($1.20)
2. Long Carriage Bolts (@ 2 = $1.80)
3. Quikrete 5000psi 80 lb. High Strength Concrete Mix ($4.35 per bag / 4 = $1.09)
4. Spray Paint ($0.33)***
*** Black Spray Paint = .99 cents Per Can, but I was able to spray 3 Concrete Blocks
Final Cost Weight for 1 @ 72.5 lbs each = $4.42 @ HD Box Store
Pix are below so you guys can see how I did it, it's pretty simple... Anyone can do it. Why go buy them Expensive Weights... Easy to do, it only take me like 40 mins for 4 of them.... This included prep time and final product and 3 days drying time...
NOTE: The pix with the Cardboards with two Holes are for holding the Cinder / Concrete Block Bolts so they don't move during drying time.
I will update once the Spray Paint Dry and Bolted to my Tractor...
:D
   / My CHEAP Tractor Weights @ 72.5 lbs Each for $7.68 :D #2
Good idea. Are those for the front?
   / My CHEAP Tractor Weights @ 72.5 lbs Each for $7.68 :D #3
Good idea! I have to say the only advantage i see in iron weight is since it is more condensed you can fit more weight in a smaller area. I have to admit though, at $52 for one 40 lb. suitcase weight, they might as well be painted gold. :laughing::ashamed: Looking forward to the pictures of your weights mounted to your tractor. :)
   / My CHEAP Tractor Weights @ 72.5 lbs Each for $7.68 :D #4
Nicely done!
   / My CHEAP Tractor Weights @ 72.5 lbs Each for $7.68 :D #5
Look forward to seeing them on your tractor!
Joe
   / My CHEAP Tractor Weights @ 72.5 lbs Each for $7.68 :D #6
Blocks are fragile. It may be wise to encase them in 1/2" plywood.
   / My CHEAP Tractor Weights @ 72.5 lbs Each for $7.68 :D #7
Good idea!
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
Standing Metal Firepit (A55853)
Standing Metal...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
2021 Kubota SVL75-2 Track Loader (A55314)
2021 Kubota...
