My cool electronic dash board project
   / My cool electronic dash board project #21
I'd vote for boost and intercooler temp...afterall, if you are going to get into that type of mod then you need to look at some engine mods......expect there will be a class for BX's at the tractor pulls!
I actually work on microcontrollers more than PLC's. This PLC is made by Moeller and is being private labled to A-B.
http://www.moellerusa.net/content/MFDTitan.shtml
As far as being water-proof, there is splash membrane for it, but I would never leave my baby out in the rain!!
Now we could go all the way with a PanelView display and wireless 802.11 LAN (which I already have). Then I could upload the Honey-do list to the tractor ... display hours till next lawn-mow... Hours of enjoyment ... Oh and read the Tractor-by-net posts under the shade tree.!
/forums/images/graemlins/cool.gif
   / My cool electronic dash board project #23
Gosh, how about bells and buzzers when the parking
brake is left on!
   / My cool electronic dash board project #24
Level indicator. /forums/images/graemlins/cool.gif
   / My cool electronic dash board project #25
I worked on a mid size Massey with a computer for several months. It had a PTO shaft pickup and electric over hydraulic PTO clutch. The PTO would shut off for no reason - only for the owner and only after several hours of shreading - a long way from town.
Even rigged an oscilloscope to look at the pick up signal. Every thing looked fine for me, and the owner did not want to pay for what it takes to keep this kind of stuff running.
He finally traded it in on a new 4WD JD. Problem solved.
I don't think computers belong on tractors.
   / My cool electronic dash board project #26
Now this one makes sense, the others are cool options, but I have done this so many times it aint even funny anymore.
That parking brake one is a good one.. I don't know how many times I've got back on the tractor and drove off forgetting bout releasing it!
One other thing on my main list was an Odometer!
/forums/images/graemlins/grin.gif
   / My cool electronic dash board project #28
add to that one for hey dummy I said NO!
or a light that has this on it /forums/images/graemlins/confused.gif
for "are you crazy"
   / My cool electronic dash board project #29
Kidding aside, shyguy you should check to be sure it would hold otherwise. I know with mine, I know real soon as in the engine bogs down. I had to have mine adjusted severly at 50 hours service, the guys could not believe it would not hold at all.
The time to find out it does not is not when you need it most
   / My cool electronic dash board project #30
Shy_Guy
Display the margin of safety or the relative danger given the height of the FEL and the angle of slope the tractor is on.
Fred
2020 INTERNATIONAL LT625 TRI AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2011 International WorkStar 7300 Acid Tanker Truck (A52377)
2011 International...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
