My first Tractor Just arrived
   / My first Tractor Just arrived #11
I spent 7 hours on my new M7040 yesterday running a 6' rotary mower and wasn't nearly as beat as when I use my old IH 424. You are going to love your new M5040 for mowing. Good choice on picking the M over the MX it really is quite a lot more machine.
I cannot wait until this evening to start using the 6ft mower. I have already begun doing some FEL work and it was a blast.
   / My first Tractor Just arrived #13
I don't know how smooth your place is but I was mowing first cutting yesterday in 5th gear at 5.2mph (540 pto speed) cutting to 3"-4" stubble height (M7040HD with KK 72" rotary cutter). I was even able to consume some beverages with out bouncing all over the place or foaming issues!
Do you have HST or Synch Shuttle. I was debating on whether or not to mow in Rabbit mode. It sounds like the spead at which you mowed that would be the case.
   / My first Tractor Just arrived #15
My M7040 has the hydraulic shuttle. I put the range in high (rabbit) and the gear selector in 1rst. At 540N on the digital PTO indicator I was traveling 5.2 MPH. Even in 3ft tall grass up hill I was not bogging the tractor down at all.
I will try it in high (1st gear). My grass it about 3-4 feet and pretty flat. Thanks for the input..............
   / My first Tractor Just arrived #17
Using my M5040HDC and Woods 8ft twin spindle cutter on Bahia requires me to use 4th gear, low, and run about 3.7mph to get a decent cut. Any faster leaves too much stuble behind....now if I wasn't cutting Bahia I could probably cut alot faster.
Curious why many of you are using 6ft cutters on your M series which clearly can handle larger cutters?
Stu
Being that I just got my M5040 and do not know all its capabilities, can it pull a 8ft disc with no problem. My father in law has a 8ft disc and says it should be able to handle it. My soil contains a lot of clay...........
   / My first Tractor Just arrived #19
I just read the Owner's manual this morning and my M7040 is rated to pull a 10' disc. I think the 5040/6040 are both rated to pull an 8'. I did some with my 3pt 6.5' disc last night and I had to keep checking to make sure it was still back there.
I am using a 6' rotary cutter because I already had one. I'll likely step up to something bigger as the budget allows.
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
NEW HOLLAND TS6.120 TRACTOR (A51406)
NEW HOLLAND...
SKID STEER FORKS (A53843)
SKID STEER FORKS...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
