my GC2300 masssey ferguson is not getting fuel
   / my GC2300 masssey ferguson is not getting fuel #1
Fragger
Huffman tx
Gilson 16 hp twin,GC2300/ Mighty Mite
My gC2300 has been shutting down , but after a few minutes it would start up and run for another 10- 15 minutes and today it finally quit for good . it is not getting fuel to the filter bowl . tank is full so what is my problem?
   / my GC2300 masssey ferguson is not getting fuel #2
When you turn the key on, do you hear the fuel pump running? You should hear a hum and clicking sound from under the seat.
If not, check the fuses. Unplug the fuel pump, and test the wires for power, and ground, with the key on.
If the pump has power, try hitting it with a hammer, and see if it runs. If that, happens you need a pump.
If the pump was running, replace the fuel filter, and test it again.
You can also try removing the fuel line, and see if fuel flows from it via gravity. A small obstruction in the tank could cause an issue there.
There is a relay for the fuel pump, under the dash, that may have failed, I would pull it and check for corrosion, and power.
There have been some ignition switch failures, I don't think you can rule that possibility completely out here.
I suggest you post future questions pertaining to your GC, in the Massey Ferguson Owning and Operating forum. People who actually own them, are much more likely to see it there. You will probably get help faster.
   / my GC2300 masssey ferguson is not getting fuel #3
drain your tank and use a shop vac to clean out tank had same problem with 1533 had little pieces of plastic in tank make sure to suck out the outlet work for me hope this helps
Ok so I found the fuel line going to the tank and followed it back , , I blew back with my mouth , nothing , I used pressurized air ,, nothing.. I got a cloths hanger and started to rod the hose out just as I was about to reach the tank , here came my fuel..I put it in a bucket and will use it to burn . I went to auto parts and bought and inline fuel filter put upstream of my bowl and fired that baby up ..Worked his azz off!! fOR ALL THE DOWN TIME HE GIVE ME ,
2010 FORD F350 SUPER DUTY SERVICE TRUCK (A54607)
2010 FORD F350...
2017 CATERPILLAR 299D2 SKID STEER (A52705)
2017 CATERPILLAR...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
