Tx Jim
New Member
I bought a HF quick hitch several years ago and discovered the lower hooks were Cat ll size instead of Cat l. I just use Cat l to Cat ll bushings to take up the slack.
I just noticed this post and your photo. I like your trailer hitch add-on! I'll have to cobble one together myself.Heres a picture of my Harbor freight Quick Hitch with my trailor balls attached. Its used mostly to move wood with my dump trailor. . . .John
I just ordered the Adapter Bracket for the 27.5" model by calling the Harbor Freight at their -800 number and using the aforementioned part number 29309-0VGA. The price is now $16.99 and shipping was $6.99 to my address in Georgia. Wanted to verify the part number still works for you all.
California said:Now that I've adapted most of my implements to accept the QH's hook, I haven't used that adapter for a couple of years.
On the rotary mower that needs a flexible-length top link, I use a loose loop of chain instead of the hook. This lets the mower follow rough ground but it still lifts normally.
Here you go.Do you connect the chain to the QH hook? If so, could you share a picture?
Here you go.
The loop is simply dropped over the top of the QH. I see in my photo I looped it through the mower's mast. It also could be just dropped over the mast.
It would be prudent to secure the chain with wire so it can't fall under the mower if it shakes loose.
I use slip-in pins at the top of the QH so I can adjust the height of the hook. I removed the hook entirely for this mowing, to create the maximum space between the mower's mast, and the QH which is adjusted as far forward as possible by shortening the tractor's top link.
Agri Supply advertises it for $17.49. I'm not sure what the shipping charges to your location will be though.
Shf141145 Top Hitch Adapter Bracket
