MY KEY IS YOUR KEY?
   / MY KEY IS YOUR KEY? #41
Bump.
As a new owner I was a little shocked to see that "my key is your key" :eek:
I think I'll be installing a hidden switch that will not allow power to the fuel solenoid.
   / MY KEY IS YOUR KEY? #42
"One key fits all" and no titles means my tractory will either be under me or in the garage. Still amazes me that dealer has 10+ BX's sitting in the front of their lot and you can walk into the parts department and buy a key that will fit all of them. Even a lazy theif could figure this one out.:rolleyes:
   / MY KEY IS YOUR KEY? #43
Same deal with the L2800/L3400. Surprised me too when I first found out.
   / MY KEY IS YOUR KEY? #44
MadReferee said:
Same for most all CUTS and heavy equipment that has a key. Kubota B series all have the same key although I am not sure about the B3030.
A bout the Same goes for cars and trucks-I've heard there are only around 10000 different keys.
   / MY KEY IS YOUR KEY? #45
Back 30-40 years ago every tractor pretty much took the same key, now each manufacturer or model has the same key.
   / MY KEY IS YOUR KEY? #46
Back in the day I left my doors unlocked in my house and my keys in the ignition in my unlocked car, sadly those days are gone.:(
   / MY KEY IS YOUR KEY? #47
A lot of the tractors that I operate have the same keys. Makes things much easier when you are jumping in and out of different tractors.
But the keys are left in the ignition most of the time anyway so it doesn't make very much difference anyway.
IMO, if someones is going to steal a tractor than they are not going to worry about how they are going ot start it. Rather they would be worrying about how they are going to transport it away. A lot of tractors can be started with a screwdriver.....
We also leave the keys in the landrover and in the quad. Someone could just jump in and drive away but they haven't yet... and I doubt it will in the future ;)
   / MY KEY IS YOUR KEY? #48
All my Kubota keys work in my 3 kubotas.
All my Bolens keys work in both of my Bolens tractors and the MTD I had.
Here's the odd one though :
My 2 Mazda car keys fit my back door.
I got rid of that car probably 15 years ago but kept 2 of the keys to use in my house back door.
   / MY KEY IS YOUR KEY? #49
When I was test driving Kubotas, the dealer said just to just use the same key. At first I thought WOW this guy went to the trouble to change all the ignition locks for his demo tractors to make it easy for the customer... then it hit me... DUH!
Talon Dancer
   / MY KEY IS YOUR KEY? #50
Old Farmall tractors didn't have any key, just a push/pull ignition switch, and a push to start switch IF you had a starter!
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1605 (A57192)
1605 (A57192)
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56436)
2022 Greenworks...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
