Gary_in_Indiana
Elite Member
- Joined
- Apr 22, 2002
- Messages
- 3,373
- Location
- Fort Wayne, IN
- Tractor
- John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
I can certainly appreciate him wanting his area to look nice. If he wants to finish cut it I'd probably let him. Nonethelss I'd still probably take the time to do that area whenever I mowed, too. It can't hurt anything and may provide the subtle hint that he's not saving you any time there.
As to the concerns about adverse possession, it's a lot more difficult to obtain than just mowing the grass. In most jurisdictions it has to be "open, adverse, notorious and hostile possession."
In the old days that pretty much meant putting up your fence and having your herd graze there or clearing, plowing, planting and harvesting. It also meant defending it with your six shooter. These are different times in most areas and one of the things required to claim "open, adverse, notorious and hostile possession" is paying the property taxes on the land. My guess is that the county tax assessor is still sending you that bill. /w3tcompact/icons/smile.gif
Still, that having been said, it can cost a small fortune to defend even groundless claims so you might want to just set a couple fenceposts on those two property corners nearest that neighbor, It should be pretty inexpensive (unless, of course, you need to buy a new post hole digger with an assortment of augers, in which case you could tell the wife you *need* this to prevent future lawsuits). Split rail corner posts with rails coming out of the rail slots to the ground pointing along your property lines should do the trick.
If you do that at the other corners of the property as well you might even avoid the appearance that you're trying to mark boundaries just on your line with him but rather just trying to decorate your property corners all the way around. Good luck. I hope this helps. /w3tcompact/icons/smile.gif
