My New BX25D
   / My New BX25D #11
The album marked " emergency landing" must have a story to it??
   / My New BX25D
I believe that pilot lost his engine on final. He put it down in my friends wheat pasture which is about a half mile from the runway at KSNL. My friend told me about it and I took some pictures. The pilot done an excellent job because that was one of the only smooth fields around. The interstate was about 1500' north of the landing spot and he wasn't too far from the fence to the south of him. Tight fit!
   / My New BX25D
I just looked at the pictures again and it appears his prop was turning when he impacted so I'm not 100% sure what happened. He was also close to some 138kV transmission lines too!!
   / My New BX25D #14
Great tractor and a beautiful home .
   / My New BX25D #16
Congrats on the new tractor, Great looking home you are building too...... Propane lines here only have to be 18", plastic or metal, doesn't matter.
   / My New BX25D #17
really? 20" deep?
Has to be at least 48" in Ontario
Sent from my iPhone 5s 64Gb using TractorByNet
I'm in Cambridge Ontario and they only went below the sod with the line from the tank to the house?
Yup, mine was put in maybe 4 inches under the sod, 3/8" copper tubing, but that was 24 years ago.
Maybe different regulations for different municipalities ???
Pete
   / My New BX25D #18
A slight thread diversion-emergency landing
This is the synopsis of that emergency landing:
On May 14, 2012, approximately 1330 central daylight time, a Piper PA-24-250 airplane, N7171P, was substantially damaged during a forced landing to a field near Shawnee, Oklahoma. The private pilot was not injured. The airplane was registered to and operated by a private individual under the provisions of 14 Code of Federal Regulations Part 91 as a ferry flight. Visual meteorological conditions prevailed for the flight, which operated without a flight plan. The flight originated from Sundance Airpark (KHSD), Oklahoma City, Oklahoma, approximately 1315, and was en route to Shawnee Regional Airport (KSNL), Shawnee, Oklahoma.
On final approach, the pilot lowered the landing gear handle; however, he did not receive confirmation that the landing gear was down and locked. The pilot stated that "a lot of force" was required to conduct the manual gear override, but he was not able to get the handle up. Shortly thereafter, the engine lost power. The pilot performed a gear up, forced landing to a field. During the landing, the right wing was buckled and the firewall was wrinkled.
According to the Federal Aviation Administration inspector who traveled to the scene, the mixture cable was bent and would not move. The routing of the mixture cable did not match assembly drawings. The mixture cable was found separated from its last clamp prior to the carburetor mixture control and the mixture control was found in the cutoff position. He also noted that several clamps normally used to route the mixture cable were not present. A grease fitting on the over center link for the nose landing gear was in line with the bend in the mixture cable.
According to the pilot, the engine had just been removed and reinstalled for an engine overhaul.
Now back to Tractors, and quit fooling around!!
BN
   / My New BX25D
Great investigative work Byrd!
I ordered a Pirahna tooth bar and skid plate from BXpanded today. I would like to build my own skid plate but I'm strapped for time and I don't have a place of my own to build it right now. I'm looking forward to trying out the tooth bar, it seems everyone loves them.
SHOP SNAP ON TOOLBOX (A55745)
SHOP SNAP ON...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2021 CATERPILLAR 303.5E2 EXCAVATOR (A52706)
2021 CATERPILLAR...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
