My new farm truck
   / My new farm truck #1
farmall 55a case
Platinum Member
case ih farmall 55a
Its a 1996 Chevy one tone dually 454 four wheel drive auto needs a little work but should fit my needs well!
   / My new farm truck #2
Should be a good old truck. Before I went to the Ford diesels, I used to run GM 1-tons with the 454, 4-speed, and a low rear-end. Beast of a truck. It'll pull just about anything. If you've never had one of these before, here's a couple of "heads-up."
First, don't expect great gas mileage. You'll likely see about 10 mpg empty, and 5-7 mpg pulling heavy trailers.
If you have problems with the engine missing, especially under load, check the spark plug wires. 454's are famous for frying plug wires. The easy fix is to buy a set of "lifetime warranty" wires. If you keep the truck, you'll use the warranty. :D (I always bought the NAPA wires)
Enjoy it. A 1-ton can really come in handy around a farm. :thumbsup:
   / My new farm truck #3
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287363"/>
I had the identical truck from 97 to 99 but with a bed and it was a light blue, almost silver. I honesty cant remember if it was a 96 or 97. Never had a mechanical issue. I had a Boss V Plow on it. It was awful in the snow and mud compared to my SRW trucks but like I said, mechanically fine.
Chris
   / My new farm truck
Thanks for the heads up! Its not going to be a daily driver so I'm not really worried about MPG. The only thing I can find wrong with it is the power steering hose is broke and more important than anything the breaks barely work! That's my first and most important on my list I don't care how much a truck can pull if it can't stop it safely then its a worthless truck! So wish me luck on the breaks!
   / My new farm truck #5
If the power steering hose is broke, the brakes won't work. My 90, 454 had hydra-boost breaks, just like a diesel. I assume a 96 is the same way. It uses power steering pressure to run the brakes, rather than vacuum like the smaller trucks.
   / My new farm truck
Thanks it sure dose I forgot all about that my grandpa's diesel is that away and its the same setup! Thanks for reminding me!
   / My new farm truck
It has weather guard boxes on it and one is missing a door! Can you order just a door from them?
   / My new farm truck #8
its nice to have a good farm truck. i picked up an old 86 chevy with a dump bed. it needed work though, brakes, carborator work, plugs, wipers, etc, but its paid for itself already, plus the dump is great. enjoy the truck.
   / My new farm truck
Heck yes wish I still had my dump truck! Not gonna be using this truck to make money just to haul my tractor and backhoe to my family members houses. They always wanting something done so hopefully this truck can help me help them!
   / My new farm truck #10
Howdy,
Nice truck!
I have a 1998 K3500 crew cab
Big Dooley
1998 National RV Tropi-Cal T/A 35FT Class A Motorhome (A55853)
1998 National RV...
24632 (A55853)
24632 (A55853)
2015 GMC Acadia SUV (A55853)
2015 GMC Acadia...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
5' MOWER (A52706)
5' MOWER (A52706)
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
