my new home made stone picker
   / my new home made stone picker #1
chickenman
this is the beginning of my stone picker
its the rotating screen drum
here is another view
   / my new home made stone picker #3
Hi. I have to admit my ignorance here. How does it work?
the drum will rotate letting the sand pass through the side and the stones will paas out the back into a hopper.
there will be a scoop and conveyer belt at the front feeding the drum.
it will be driven off the pto.
when finished it will be about 20' long, 4' wide and 4' high.
its a smaller version of the one here.
rock picker
   / my new home made stone picker #6
Interesting gadget, I hope the construction goes well for you. Please post more pictures as your project advances.
   / my new home made stone picker #7
chickenman:
is this something you intent to tow with tractor , lower to scoop the rock (near or above ground I assume?) and power raise after scooping the rock and rotate it and let rock rolle to the back into a low slung trailer? ok that is just my first thoughts, but I ****-u-me that it is for rocks of 10" or less across correct?
MarkM
my version will pick up stones of 1/4" and bigger
comercial units all seem to do 1/2" or bigger
and they cost an arm and a leg
other than being large its realy a simple device
it will be towed behind a jd 4310
   / my new home made stone picker #9
Wow. I've never seen one of those. Very interesting. Yes, and please do post more pictures as it progresses.
   / my new home made stone picker #10
I live very close to a sod business and they have a couple of these that need a large tractor to run them. They have some of the bigger Deere's and NH's they use for these and for plowing the ground under come seeding time. I'll try and find one of them and get a picture if you like. They also have a large PTO water pump that needs at least a 100HP, it has I think a 10" suction line. Pretty impressive when there watering in the summertime.
Steve
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2019 FREIGHTLINER...
flooring (A53424)
flooring (A53424)
2024 VOLVO VNL760 SLEEPER TRUCK (A54607)
2024 VOLVO VNL760...
2018 JCBTruss Jib Telescopic Hyrualic Boom (A53421)
2018 JCBTruss Jib...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
