midlf
Platinum Member
For my '93 F-250 I play around on www.ford-trucks.com/forums/index.php
HGM said:Inn '94 they built two different engines for these trucks.. The actual Power Stroke was a late build. If it truely has a Power Stroke, I'd have to think about it a bit, they useually dont have idle problems.. The earlier engine has an injector pump(as you mentioned).. If you can see an "octopus" of lines toward the front of the engine and leading to each injector, the pump timing could be off sinse they just replaced it.. Any diesel shop should be able to help.. I'm in a rush this morning, I'll check for your reply on the engine and add any other info I have later..Good luck..
As along as it drives OK would there be any danger in leaving it as is?
dpdee13 said:See if you can verify the temp gauge by another method. If it is really running that cold could be as simple as tstat stuck open or perhaps the radiator cap isn't holding pressure like it should. Diesels tend to run cooler than most gassers. Sounds/looks like a real nice truck, good luck with it.
Dave
