Great Tractor !
The 221 has been really good for the most part. For me, it has been a time of learning and getting used to a new machine. The engine runs smoothly and has plenty of power for my needs.
I have had a few issues with an oil leak out of the mid mount pto. The dealer is not sure of why this keeps happening. I think some stubble when I was doing some brush hogging is the culprit. The MM PTO is really low to the ground.
The Mid Mount Mower can be a ***** to attach to the tractor. The actual connecting is easy but the mower is a bit cumbersome to move into position. I think the wheels on the back of the deck need to be castors like on the front. The rubber wheels are hard to slide on the cement. I also have read the MMM manual and there is no section in the book on how to connect the deck to the tractor. I have told my dealer and contacted Yanmar about this. Another issue with the MMM is I wish there was a height adjusting knob on the tractor to better control the height of cut. The mower does a great job of mowing and discharging the grass.
I also had a quick hitch installed so hooking up my cutter and box blade is easier.
Over all the 221 is a really nice tractor. I really enjoy using it. Like I said earlier it has been a learning curve for me. It's surely different the Cub Cadet I had for over 10 years.
When you install or remove the MMM deck you need to turn the rear deck wheels 90 degrees so it will roll in and out. Really takes the work out of it. I have not been overly happy with the scalping on my 221 MMM. Seems like my other mowers gouge and scalp much less. I have 33 hours on my tractor and a bunch of bolts and pins fell out of the mower. Poorly assembled by the dealer. Dealer charged $35 for $10.00 of pins and clips. The next closest dealer is 100+ miles from me. My mower has been down more than up as my dealer could not provide a parts list and made me bring the parts in before he would order. Also, would not answer questions as to if there is a warranty on the deck. Mower is down again with a shredded belt and belt took out the plastic guards when it went. Looks like I will need to take the gear box off the mower to change the belt. Hmmm.. bad design. Also still do not have any manuals for this portion of maintenance. I like the tractor but service has been sub par and not so sure about deck design. I have lots of other mowers, tractors, bobcats, excavators, etc. from other dealers and would say "Avoid Wood Sales and Service out of Black River Falls, WI"
