My tractor is arriving tomorrow and have a few questions?
   / My tractor is arriving tomorrow and have a few questions? #31
Wow! You've got a beautiful setup!!! Congratulations. I'm no expert, but here are some of my bits of advice:
Seriously consider getting a Pat's Easy Change 3 point hitch attachment. Best thing I've purchased for my tractor.
In Alabama you probably don't need an engine block heater or to use diesel fuel winter additive, but those come second to mind in the northern states.
If you don't already have one, get a good grease gun - or two. You'll need it. I have two - both one-handed grip - one with a fixed nozzle and one with a flexible nozzle - each has its uses. One little bit of advice my JD dealer gave me was to put a little grease any bits of tractor that aren't painted - like bolts and threads (after tightening) for protection. Oh, and disposable gloves and lots of paper towel.
Not sure how you fuel up your toy, but my favorite fuel containers are these now ... the button controls the flow without any mess. The newer model has "wings" that allow me to have a hypodermic needle-type grip, which is pretty comfortable. I have a Suburban and was afraid of a mess in the back, so I bought a few big Rubbermaid tubs that each fit two 5 gallon cans - in case of drips: Amazon.com : No-Spill 1457 5-Gallon Poly Diesel Can (CARB & EPA Approved) : Lawn And Garden Tool Gas Cans : Patio, Lawn & Garden
Not sure if its an issue for you, but get yourself a good saw and "loppers" to cut branches out of the way of the cab. Actually, I ended up buying a little JD mower to do the trim work around trees. My wife does most of that mowing.
If you didn't have a cab my most important bit of advice would be to wear your seat belt - but you should probably do that anyway. And don't take a chance of rolling that beauty.
Not sure if you got an answer to the RPM speed. Follow recommendations for attachments. For my mid-mount mower I start it at lower RPM and then try to run it at the "PTO" RPM - marked on my tachometer. I find I do most work at that RPM - or a little less maybe. My 3320 really only sips fuel, so saving fuel is never really on my mind.
Oh, and you may want to run by a JD dealer and pick up an extra ignition key ... before you wish you had.
Be safe out there! Don't take chances with the PTO. Keep people far far away from the tractor when out working. They can be hard to see.
KennK - I appreciate the long post and being detailed. I really truly appreciate the time you took. I'll take your advice too! A BIG THANKS!
Glad to hear of the quick fix. Makes you feel better that it wasn't something that you yourself missed, huh?
Sounds like a great first day with the tractor. 25 acres is a lot of ground to mow - must have been sweet in the comfort of the cab!
It was a nice afternoon that was for sure! :) In fact it got so cold a few times with the ac set on low, I still had to turn it off.
   / My tractor is arriving tomorrow and have a few questions? #34
Great looking tractor. Read all the "Safety" Threads here on TBN. Safety is #1 for you and your Family.
Charlie
   / My tractor is arriving tomorrow and have a few questions? #35
Very nice tractor, enjoy!
   / My tractor is arriving tomorrow and have a few questions? #36
I have had two of these tractors, and a couple of things that come to mind. I have had antifreeze leaks on both tractors from loose band clamps. So be on the look out for that. While it is new, I would verify my fluids more frequently until you get comfortable that they are staying full.
That 8 foot cutter should be able to be run on economy pto, or normal, which ever you want. The key to pto equipment is that you want to run them at 540 rpm. That gives you the best results. If you have the tractor set on economy pto, your max engine rpm will be 1,700 rpm, but your mower will be at the 540 rpm. If you have it set on normal PTO, then the engine will need to be where the other PTO emblem is on your tach. I think its around 2300 engine RPM to achieve a 540 rpm on the mower.
I run a 15 foot JD HX 15 batwing mower on mine, and it needs the normal PTO setting to keep from bogging down on hills.
I wouldn't run the PTO slower than 540, as your results won't be as good.
I appreciate the feedback. By chance does your parking break light come on or doesn't? Mine doesn't but manual states that it does.
1305 (A58374)
1305 (A58374)
Wood chipper (A56857)
22' x 23' All Metal Garage (New/Unused) (A59225)
22' x 23' All...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
1995 Rinker Captiva 190 (A56435)
1995 Rinker...
Deere 335P (A53317)
Deere 335P (A53317)
