my tractor runs but won't go please help
   / my tractor runs but won't go please help #1
mercellugnut
yanmar
I just bought a 2wd little yanmar 18 hp I believe that is the 1500? I was bush hogging yesterday and all of a sudden I hit some tall grass and the tractor bogged down and stopped. It was still running but it would not go and tprowling was not spinning. I can put it into gear while it is running but when I let out on the clutch nothing happens just a slight moan from the bell housing area.
Any suggestions or help would be amazing and greatly appreciated.
   / my tractor runs but won't go please help #2
I would suspect your clutch plate or transmission input shaft has failed. I think you need to split the tractor open at the bell housing / clutch plate. You will need to support the front and rear sections as you will have 2 tractor sections . What is broken you will only learn when you split the tractor. Been there done it.
Craig Clayton
   / my tractor runs but won't go please help #3
Craig Clayton
Ditto.
   / my tractor runs but won't go please help #4
Did you check the high /low shifter to be sure it hasn't jump into Neutral position?
But this wouldn't make the sound you described from the bell-housing
   / my tractor runs but won't go please help #5
Make sure the clutch is adjusted to engage and that you just didnt burn up the last bit of clutch you had, untill you readjust it. Just a thought to check that.
Been 2 days i guess the bad news really effected him and he dont want to come back?
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
2017 INTERNATIONAL PRO STAR SERIES (A52472)
2017 INTERNATIONAL...
2006 Husqvarna YTH2148B Riding Mower (A51694)
2006 Husqvarna...
LINDE H80D FORKLIFT (A52472)
LINDE H80D...
2016 FORD F-150 (A52472)
2016 FORD F-150...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
