I disassembled the check valve assembly and all seemed well. The only thing I wondered about is the poppet rear has a gap where a o-ring looks like it may have gone, but isn't there:
Although, the press is able to go from quick advance to slow as expected. If that needed an o-ring, the worst that could happen (I would think) is that it wouldn't be able to quick advance. It would be able to achieve the high force requirements, it would just take longer to get there.
This makes me think even more that the problem is with the cylinder itself. How about my pressure relief valve swaps with the solenoid valves? Wouldn't you agree that I ruled them out by doing that? Who wants to bet against me when I say it must be the cylinder?
edit (add): should mention that there was no hole in the poppet (I might be naming it wrong, maybe it is called the shuttle and the poppet is on the other side). The other side has the conical pieces that actually seal off flow. One of those had holes, but they were quite large and clear.
