NAA rear wheel fell off
   / NAA rear wheel fell off #11
I'm not sure if your axle setup is exactly the same as my 600 so I have to toss that disclaimer out. I also don't remember if there are any brake components in the way. So assuming brakes are clear and everything is the same.. It's pretty simple just unbolt the hub from axle flange and slide it out. Mine has shims between flange and hub so I just carefully cleaned them and returned them to original position. If you scored a good shaft and hub assembly from the junkyard I think it would be a few hours labor if you have the tools and means.
naa has a completely different hub and axle setup than a naa. naaa uses 8n technology. :)
   / NAA rear wheel fell off #12
Fix it right. New or junk yard axle. But dont do what the previous owner did.
Aside from it being really dangerous and stupid, it is possible to damage much more expensive parts in the process.
What would happen to YOU if you were in road gear (or even on the road) @ 14-15 MPH??? Sure it dont sound very fast, until it happens and your in the hospital
i agree..
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53473)
2017 Ford F550...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53473)
2012 NEW HOLLAND...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
