Nailing shingles
   / Nailing shingles #31
As others have sugested, I've used 1/2 inch staples in this situation and the shingles have been on that building for 11 years or so now. I'd do it again.
Cliff
   / Nailing shingles #32
Cliff
   / Nailing shingles #33
Staples will not have the holding power of nails. If you are in a high wind area, I'd be somewhat concerned about that option.
   / Nailing shingles #34
   / Nailing shingles #35
If you try to use 1/2" nails you will hammer your fingers mercilessly, holding them between thumb and forefinger. If you feed them between you index and middle finges you will nail though the loose skin on a nuckle and you'll be nailed to the roof. Use longer nails, and try one of the cover ups suggested. /forums/images/graemlins/tongue.gif
   / Nailing shingles #36
   / Nailing shingles
As always, TBN is a great source of information. Thank you, everybody.
I tried stapling a shingle to the plywood as a test and I dont trust it at all.
But in local HD they have felt paper in rolls for flat roofs. This type of cover is glued using cold cement. Would you think it would stick to steeper roof also? It would save me some time too.
But this is my last attempt for different solution - I will most likely use normal nailes and cut them off or cover them up or something like that
   / Nailing shingles
   / Nailing shingles #39
I would use longer nails and put a ceiling inside- Rolled rooing is a pain- you still need to nail the upper edge down- at least that's the way I would do it.
   / Nailing shingles #40
2014 INTERNATIONAL LF687 SLEEPER (A52576)
2014 INTERNATIONAL...
John Deere 9620R Tractor (A53342)
John Deere 9620R...
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
Scag Mower (A50324)
Scag Mower (A50324)
