Gulkana
- Joined
- Feb 25, 2020
- Messages
- 27
- Tractor
- Bolens g154. Ford 3400 gasser, Massey M35 diesel
I am finally getting this little Massey Ferguson M35 diesel tractor up and running. The 3 point system on it wasn't working properly when I got it. The previous owner told me it would only go up about 6 inches and slowly at that. He had a guy put in a new cylinder and piston a few years back but said it still wasn't working correctly and the tractor sat not running since.
I installed a gauge on the cover to check the pump pressure. I engaged the lift lever and the pressure shot all the way around the dial and pinned back at zero. Then one of the studs on the cylinder flew out of the top of the cover and across my shop. I shut everything down and pulled it all apart. Below are a few photos. I have no idea what happened to the piston. The cylinder was pushed away from the bottom of the cover and 2 of the 4 studs were broken off. It looks as though there was no releases of fluid and it just built up until it pushed the cylinder. I suspect the safety relief valve is shot. But I dont know what exactly is going on here. The original cylinder is in the photo below the one with the huge crack in it. The PO installed a new cyclinder at some point. I sent a magnate through the case and I only found the debris from the cylinder damage. It doesnt look like anything else is broke. I did check the pump pressure via the tube at the top and fluid is coming out when engaged so it looks like the pump is working. I am thinking the safety relief valve failed but I don't have a lot of expiernece with those and what happens when they fail. Anyone have any idea what went wrong?
