Need a good rotating laser level
   / Need a good rotating laser level #1
mfairbank
Hello,
Im building a pole barn 30x40x16 and am needing a good laser level to get everthing level quickly. Im needing something that will not be to costly but that is accurate and good quality....any brands and styles that anyone has used and worked well for them??
Thanks,
Matt
   / Need a good rotating laser level #2
What is your cost limit?
What is your accuracy range?
   / Need a good rotating laser level #3
I just got this one to help me on the layout of my barn. I didn't think much of it before I bought it, but it has been a tremendous help. I don't know how I got around without it now.
Shop Bosch 800' Beam Self Leveling Rotary Laser Level at Lowes.com
The website is a little vague but at the store, that laser comes with a tripod, a measuring pole and a laser receiver that beeps when you have captured the laser(you mount it to the pole). This is so you can level by yourself. It's a little pricey but it's value is spot on.
   / Need a good rotating laser level #4
Pacific Laser Systems pls360 will give a constant visible level line using optics instead of rotating the head. I have owned one for years and is an amazing tool.
cost limit is around 200 buck give or take 50 dollars and the accuracy range is probably about 1/8" to about 50 feet
   / Need a good rotating laser level #6
I have a Spectra. There are two grades of laser levels out there. Both will do the job, but one is going to be alot more accurate over a longer range and weather conditions. What is your budget and how many other uses will you have for it?
For just building a pole barn, I'd buy 50ft of hose and make a water level. Cheap, accurate and easy to use.
Eddie
   / Need a good rotating laser level #7
if its only for a single job....... go to a rental yard. Ive rented professional grade lasers for $50 a day. and i can set everything i need to set in 1 day with no help.
I do own an old fashion glass site transit /linker rod from back in the 80's, and i still occasionally use it. but rarely.
Well the main reason im buying this laser level because of the pole barn but i do plan to be doing a complete kitchen remodel and a add on to my house. So im needing a level to last me several years....and i just like the convience of having my own tool. :) im sure you understand...lol
and of course the wife is gonna use it in the house for hanging pictures..and stuff.
Im currently looking at one its a Johnson Level 40-6515 Self-Leveling Rotary Laser Level
Amazon.com: Johnson Level and Tool 40-6515 Self-Leveling Rotary Laser Level: Home Improvement
At first i set a price range for about $100 to $200 but with doing more research i always want the best so i keep going up in price.
   / Need a good rotating laser level #9
Water level cheap easy accurate and you can see it in daylight.60 ft 5 bucks at the box stores.That's what I ended up using after I could not see my fancy laser.If you decide to go with a laser go high end or you won't be able to see it.
   / Need a good rotating laser level #10
I have a water level also. used it to set up batter boards years ago. they do work great...and durn cheap.
74in FEL HD Round Back Bucket (A52128)
74in FEL HD Round...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2018 LAND ROVER Range Rover (A50324)
2018 LAND ROVER...
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
1041 (A50459)
1041 (A50459)
