Need a little help with my 10LA FEL
   / Need a little help with my 10LA FEL #1
marc2000gt
Bronze Member
Appling, GA
New Holland TZ18DA
I need aid in taking it off and putting it back on. How is it supposed to be positioned and such? I popped the hoses off but did not end up getting the loader off. Then when I put the hoses back on, I had a heck of a time getting the two middle hoses back on. They had pressure on them. I do not have a book on the loader, just the tractor.
   / Need a little help with my 10LA FEL #2
the key to getting it connected on a reinstall is to keep it in a completely relaxed position when taking it off, it seems the more care used when taking it off and disconnecting the easier it goes back on.
   / Need a little help with my 10LA FEL #3
With my 114, you need to keep the hoses on until the mechanical parts are off the tractor, then power down and disconnect. You use the hydraulics to position the bucket and arms correctly with respect to the "foot" and to lift the loader from the frame on the tractor. Then move the tractor slightly, shut if off, move the lever through it's cycles to relieve pressure, and finally disconnect the hoses after which you restart the tractor and slowly back out from under the loader.
Thanks for the help. I figured it must not have been in the right position. So when I do get it off does it sit upright so the tractor can go right back into it? Or does it have to be supported?
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
1067 (A53342)
1067 (A53342)
RIGID TOOLBOX (A52472)
Payment Terms (MUST READ) (A50775)
Payment Terms...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
