Rotary Cutter Need a new PTO shaft for an old Hardee rotary cutter
   / Need a new PTO shaft for an old Hardee rotary cutter #1
ml8163
Franklinton, NC
Fordson Dexta, Massey Ferguson 2615
I have an old 6ft Hardee rotary cutter that I need a new PTO shaft for. Had this cutter hooked to an old tractor for many years. Just bought a new tractor and the PTO shaft wont go on the PTO. Looks like over time the spkines have twisted. It is a Hardee model number T 166 LT. Does anyone know where I can buy this part?
   / Need a new PTO shaft for an old Hardee rotary cutter #2
Can you not buy replacement pto shafts at Tractor supply?
Or does it have to be a Hardee specific shaft?
I've never bought a PTO shaft so I don't know if I need a Hardee specific shaft or not. I will check around some of the local agr-equipment stores though.
Thanks for the help!
   / Need a new PTO shaft for an old Hardee rotary cutter #4
IF not specific to Hardee, then they are just a generic pto shaft.
good luck
   / Need a new PTO shaft for an old Hardee rotary cutter #5
You might just need a new "end" on the shaft, probably a U-joint yoke. I would not think it to be too expensive to have done at a shop that repairs PTO shafts, if you don't want to try to change-out the yoke yourself. Make sure the rest of the shaft is "good" before replacing parts of it.
A new shaft might have safety guards your old shaft does not have- something to think about. And maybe a slip clutch instead of a shear pin, which you might want??
A photo or two of the cutter end of the PTO shaft, and of the input shaft of the cutter, would probably get you more suggestions.
The U-joint yoke is exactly what I need, but failed to put into words. And yes... I think a new shaft could have some safety guard challenges. That is why I was asking about the particular model.
I just got off the phone with Hardee and got the new spline yoke ordered for $59.92 plus shipping!
Thanks for everyone's help!
MINI EXCAVATOR BUCKET 24 (A55745)
MINI EXCAVATOR...
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
1995 Generac 94A04738-S 125 KW Towable T/A Diesel Generator (A55851)
1995 Generac...
Estate Equipment Auction 9/27/2025
Estate Equipment...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
2018 Kubota...
