Need a tractor
   / Need a tractor #11
Check all brands out. Make sure u find a good dealer that's the most important.
Brands to consider.
Kioti
Kubota
John Deer
MF
many others
   / Need a tractor #12
You mentioned a Kubota 3130. I had a 3130 and used it for the same tasks that you plan. I never loaded a dumpster with it though but my dumptruck sideboards were 6' and it dumped over those fine. Im sure you can't get into a new 3130 with loader and grading attachments for less than $15000, you are looking at more like $18000-19000. Unless you find them used, you will be paying well over $1000 for just the attachments to grade, level and clear. Im talking a nice box blade and landscaping rake. Buy heavy duty attachments for the 3130 (or any tractor that size). Thats enough tractor to bend up the cheap ones in a second. Also towing a tractor/loader/and implements that size with 1/2 ton is a little much.
Diesel is the way to go. If you are paying cash for it, you would be fine with a used one. If you are financing, you may be better taking advantage of 0% on a new one.
Taking into consideration the use you describe, the fact that you have a price limit set and you want good parts availability, I would buy a used, major brand (JD, NH, Kubota, Kioti, MF) in the 30-35 HP range. Doesnt really matter what transmission as long as its got a forward/reverse shuttle.
   / Need a tractor #13
Check out the New Holland TC30, it's an older style but a workhorse. You should be able to buy a new one with FEL, brushhog, and blade for $15,000. The TC30 with 7308 FEL with the bucket DUMPED specs at 83.3 inches, and a maximum height of 100.8 inches. Lift capacity at full height is rated at 800lbs.
Nothing against the other brands, they may even beat these figures. I know Kubota, Deere, Koiti etc make good products.
   / Need a tractor #14
Sounds like you might be think'n penny wise pound foolish. If you would only save $2500 bucks a year, don't bother. Keep highering it done and spend your time getting more work. A skilled operator with the right tractor can out work an unskilled one any day.
Having said that. Ain't no way no how you are going to remove 3 inches of top soil with a 20 or 30 hp tractor and make money. You need something much bigger, heavier and with t-n-t. Something like http://www.equipmenttraderonline.com/caddetail.html?/ad-cache/9/5/9/81524159.htm good luck and keep us informed.
   / Need a tractor #15
Hey member12,
For your price range you may want to take a look at the Kama. I just took possession of the 55HP version. It is a powerful tractor. Didn't have a dealer in the area, so I had it delivered.
Good Luck,
TR
   / Need a tractor #16
</font><font color="blue" class="small">( I The climate is southern Louisiana- hot and sticky summers around 85 degrees. )</font>
Are you from LA? If you are not, you are going to wish the temperature was 85 degress come June-September. /forums/images/graemlins/grin.gif
40 CONTAINER W/CONTENTS (A55745)
40 CONTAINER...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2013 Dodge Charger Sedan (A55758)
2013 Dodge Charger...
2022 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A56129)
2022 FREIGHTLINER...
2014 Chevrolet Caprice Sedan (A55758)
2014 Chevrolet...
