Need a weedeater trimmer
   / Need a weedeater trimmer #31
Glad I ran across this and Bird's comments. I have been eyeballin' an FS-55 not far away for $230.00 OTD. I usually go big I just do not need it.
   / Need a weedeater trimmer #32
I bought the Honda 4 stroke 7 years ago, the smaller one with the 25cc engine. I really like it, relatively smooth, easy starting, although I occasionally wish I had gotten the 31 with a bit more power. It sips fuel, I run out of go long before the fuel tank is empty. I added the Speedfeed head, last year, wish I had added it much sooner, I hated refilling the Honda head. I wish Honda made more attachments for the unit like Stihl and Echo do. I think when/if this one dies, I will get an Echo model that has the ability to add more attachments. Honda doesn't make, or recommend adding, a brush cutter blade but several manufacturers make ones that fit.
Have a look at the 324LDX Husky. Its a Honda motor. It can also take attachments.
HUSQVARNA 324LDx - Trimmers
I have a honda HHT25 trimmer. It works great, lots of torque , very quiet and easy to start, but its heavy compared to its competition. A great unit as you say.
   / Need a weedeater trimmer #33
This is what I have. I bought cheap and junk too many times, and finally spent a little extra to get the best. I have Stihl chainsaws and like them, but Echo is way better and I will never buy another Stihl.
Eddie
:thumbsup:I bought two of those one with saw kit and one witout. The big thing you need on these is balance and Echo's are perfect.
We have two pieces of ECHO equipment. A backpack blower and an "attachment system" (power head with string trimmer, brush saw, hedge clipper, and edger). No problems with either. :thumbsup:
   / Need a weedeater trimmer #34
I would look for something less than 10lbs. I had a Weedeater sst25 and it was great. Started to lose a little power after 5 years so I sold it. I just got a Husky 223L but the shroud gets too hot. I'll either return it or add some shielding. Look at the Hitachi CG22EASSLP on Amazon. It has good reviews and a 7 year warranty. I just wonder where to take it for service.
   / Need a weedeater trimmer #35
Weight is a pretty important consideration for my trimmers. One pound extra doesn't sound like much. But that one pound extra matters a lot to me.
   / Need a weedeater trimmer #36
That is why I like the big trimmers with the full shoulder harness. Makes a big difference. But... having the big handlebars, and being hooked in to the harness, neither my older Husky 225R nor the Honda 31cc 4-stroke, neither work well for detail work. If you have bulk weedeating to do though, that is the ticket...
Thanks for all the post on weed trimmers.
I live in the mountains and most of the trim work is up and down hills here.
Light-weight is at the top of the list for a trimmer.
I have 3 stihl chainsaws, an Echo trimmer and a Echo backpack blower.
All of these start easy and work very well.
I have had and wore out several cheap trimmers, some lasted 10 years or more.
I have a horse of a weed-trimmer made by weedeater, too heavy though.
I just need one more light-weight weed-trimmer so wife can enjoy as well.
I will research all the trimmers mentioned here prior to my purchase.
Thanks,
sherpa
   / Need a weedeater trimmer #38
IMHO Husqvarna trimmers have the best weight/speed ratio. I have used them all and would really recommend the 323 or 326 Husky trimmers. Very light at 9lb.
HUSQVARNA 323L - Trimmers
   / Need a weedeater trimmer #39
Get an Echo SRM 225, they are around $200. It is the smallest of their commercial trimmers. They are almost bullet proof. More than likely it would be the last trimmer you would need to buy.
I've got an Echo with the head that takes the individual pieces of string instead of the spool. It works great for home use; just pull the worn pieces out and insert the new ones. No spool, no winding. It probably would be tedious for commercial use, but for my purposes it works great. I just cut off a couple of pieces of string about 6 or 7" long and stick them in my pocket; I usually use two sets per trim. I wouldn't trade it for the spool type.
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2016 CATERPILLAR 277D SKID STEER (A51246)
2016 CATERPILLAR...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
2010 Ford Focus Sedan (A51694)
2010 Ford Focus...
2012 Ford F250 XLT, Super Cab Long Bed (A52384)
2012 Ford F250...
