dmccarty
Super Star Member
The real question you have to answer, is how deep will the well have to be to hit water? Nearby wells can give you a clue.
You could run solar to run the pump. Even if the pump only brought up a small amount of water per day if you have enough water storage that might be all you need.
Solar should be able run a pump to pressurize the drip lines as well.
With solar or a generator you will need to secure as best you can the equipment.
You have some options but I think what you do will depend on how much each option is gong to cost.
Later,
dan
Later,
dan
