Z-Michigan
Veteran Member
My tractor has 540 PTO rpm at 2200 engine rpm. I can run 2200 engine rpm with the cutter attached, on, and cutting heavy grass with the throttle lever only about 1/3 the way open.
Tscott9330 said:The tractor is a 42 HP Branson, 6' would seem resonable for a tractor that size, No? 5 HP for ever foot of cut would be 30 HP.
I do not care about resale value because I will probably use whatever I get until it is sofar gone that even I can't fix it, and I can fix anything.
Tom
LoneCowboy said:You can buy the bush hog to start with
or you can buy another cheaper brand and then replace it in 1 to 5 years with the Bush Hog you should have bought to begin with.
JMHO
Soundguy said:Why would you think a light duty cutter, used for light duty will only last 1-5 ys.
I have one of those KK hogs, and have cut many a ant hill, 2" woody sapplings, and 7' tall brush so dense i couldn't even see thru.
It's over 8ys old now and still going strong.
soundguy
Farmwithjunk said:I can't speak for Brian, but I can understand where he's coming from. It's relative to volume of use. You use your KK mower in conjunction with 2 other larger mowers on a total of 13 acres. So the use is somewhat limited relative to the way Brian (or myself) uses a mower. (My crew logged a little over 700 acres last week) One of my competitors uses KK 6' mowers in the same capacity as I use my Bush Hog 6'er. He has to replace them as often as 2 times per summer, where I've already logged 3 years use on the Bush Hog 286, with no signs of it failing. The cheaper brands (as well as lighter duty models from the "premium brands" in many cases) just don't hold up under constant use. That's when you really notice the difference between a $600 mower and a $2000 mower. By the same standards, my 286 Bush Hog mower wouldn't last a week if I used it in the same conditions as we use the Bush Hog 406 (Extreme heavy duty mower)
Not ALL "higher priced" mowers perform better (simply because they're more expensive) but the better performing mowers are generally in the more expensive range. Because of certain factors such as blade type availability as an example, my Bush Hog mowers leave a better cut under most conditions than that competitors KK. Paying customers notice details like that.
So, if your volume of use is relatively low, your mowing conditions are light and/or results aren't always critical, a less expensive mower may be the ticket. On the other hand, they just don't give satisfactory results for many of us. Also, some folks are willing to spend a little extra to get that added quality even if they don't make 100% use of it.
Soundguy said:It seemed like the original poster was indicating light / light duty use.. thus the money saving recomendation for an economy cutter... and he was on a budget.. etc.
Before I had my larger tractors and mowers, the economy KK had to do all the work... though as you point out, in the last 4ys, it has been mainly used to clean corners, and in wooded areas the 10/15' mowers can't get to.. etc.
soundguy
