Need advice on broadcast spreader
   / Need advice on broadcast spreader #11
Ok, you’ve got the other type drive gear. The agitator shaft on mine goes through plastic so there has never been a corrosion problem there. I did hit it once and broke that area so took another piece of plastic sheet and riveted it to the bottom of the hopper as support for the shaft, has worked fine.
   / Need advice on broadcast spreader #13
Tiller,
I sent you a PM.
Matt
   / Need advice on broadcast spreader #14
I think I had the SAME Agri-fab spreader you had. I set it out by the curb and someone took it away. I don't know who, but I wish them better luck with it than I had.
I looked at a lot of brands and ended up with a 3pt spreader made by Herd. It has a galvenized hopper and a very thick cast bottom plate that, even if neglected, would take years to rust through. The impeller blades are also have cast as opposed to bent sheet metal blades. All parts are replaceable should they need to be replaced. Best of all it was reasonably priced at roughly $420 and is MADE IN AMERICA too. The model is a Herd M-96. They make larger units. I'm very impressed with them.
</font><font color="blue" class="small">( <font color="blue"> I recently purchased Agri-Fab's 125 Lb. Tow Behind Spreader and it seemed to pull okay behind my Sears DGT 6000. </font> )</font>
That looks like mine Carl. Just pay particular attention to cleaning and oiling where the shaft goes through the hopper and maybe you'll have better luck than I did.
</font><font color="blue" class="small">( <font color="green"> I looked at a lot of brands and ended up with a 3pt spreader made by Herd. </font> )</font>
Bob, do they make anything smaller? I just need something to pull behind my Murray Lawn mower. That unit you have sounds like a real bargain for a 3pt spreader.
   / Need advice on broadcast spreader #17
I have the Agri-Fab made Craftstman. It's about 10 years old and it likes attention. I usually roll the drive wheel now and then cause mine locked up one time too. I spread about 150 lbs of hard red fescue at the church a few weeks ago over some ill prepared ground. The fescue did not feed out well due to the tiny agitator so I had to run wide open in high gear on my 15 hp Mitsu to keep
the hopper bouncing. Got a good stand but I'm sure our dry weather will kill it.
   / Need advice on broadcast spreader #18
Have not had any trouble with mine..... but. If I ever get another spreader it will be one that I can turn on and off without getting out of the seat and one that holds the most material.
   / Need advice on broadcast spreader #19
I just purchased an earthway walk behind broadcast spreader, after looking at all the other junk from Home Depot and Lowes. I was impressed buy the quality. The heavy gear box and the 10 inch air tires. I know that they make pull behind models. I purchased mine at a local Agway Dealer. Good luck.
So far I am leaning towards the Earthway spreader. I still need to check out the Beefco unit before making final decision.
</font><font color="blue" class="small">( <font color="red">If I ever get another spreader it will be one that I can turn on and off without getting out of the seat and one that holds the most material.
</font> )</font>
RSKY, I have seen some models that shut off as soon as you stop moving. Could be a nice feature to have.
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A50397)
2010 Gleaner 9250...
2008 Club Car Transporter 4 Utility Cart (A49346)
2008 Club Car...
2012 Ledwell 130BBL Vacuum Trailer (A50860)
2012 Ledwell...
Unused 2inch x 50ft Discharge Hose (A49346)
Unused 2inch x...
2011 Liebherr L586 (A50397)
2011 Liebherr L586...
