Need advice on my YM1301D
   / Need advice on my YM1301D #11
Do the needle bearings actually run on #61 or is #61 just a spacer between them?
No the needle bearings are inside the cog #59, the bushing #61 is pressed inside the top of the housing #5 and the kingpin #5 pivots inside of it. The bushing's got holes and spiral groves on the inside to let the gear oil move between the surfaces, has a slightly brassy look to the metal, guess it's made of something a bit softer than the kingpin. http://www.hoyetractor.com/mm5/merchant.mvc?Screen=CTGY&Category_CODE=13014WDINT
Anyone Know if the 1301D front 4WD axle is used on other models?
:anyone:
Thanks Winston, I found the proper ones, Hoyes did have them just not liked off of that diagram.
I presume these just press out and the new ones press in?
   / Need advice on my YM1301D #15
No manual here but I would assume the same, press the old out and the new in.
Bushings arrived from Hoye today, they look wrong to me, what do you think?
Originals are bronze coloured, longer and have oil grooves and holes in them:
   / Need advice on my YM1301D #17
I would think size is the most critical issue. If the bore and od are the same I would think oil grooves might not be necessary. How much shorter are the bushings?
   / Need advice on my YM1301D #18
Matches mine ;)
   / Need advice on my YM1301D #19
Yea hoye has stuff that for some rreason they dont list. This is why they say if you cant find it to call them. I have found this to be the case in something i looked up there before. Dont remember what, but was some insugnifficant part.
Thanks. It says "1301D repl. 194210-14270" I guess that means SB1427 is a replacement for the original 194210-14270 ? It's definitely shorter than original and is steel not bronze, added to that there's no oil channels it's likely going to cause wear on the kingpin. Being a perfectionist really is a pain some times...
2023 JOHN DEERE 7R210 LOT NUMBER 95 (A53084)
2023 JOHN DEERE...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
