Buying Advice need advice on older large JD tractor
   / need advice on older large JD tractor #1
bdog
Elite Member
Texas
John Deere 6130M
I am in the market for an older 70's - 80's model JD tractor with cab and 75-150 HP. I have 15k to spend if need be, but would prefer to keep it closer to 10k if at all possible.
I am needing the tractor for just basic farming on a small scale. That is plowing and planting a maximum of 60 acres.
I know nothing about these older tractors, but am strongly leaning towards JD as parts seem readily available and the JD dealer is 5 miles from house. The next closest dealer of any brand is 25 miles.
   / need advice on older large JD tractor #2
Same reply from me as on your other post.
John Deere 4020 Diesel. Price probably 6 to 10 K depending on condition.
Egon /forums/images/graemlins/grin.gif
   / need advice on older large JD tractor #3
I was in the same shape, and ended up getting a 2950 with cab/air. It is about 90 hp, and has 16 speeds. The 6 cyl engine has been doing very well, and is known to be a good one. I've been disking, and plan to do a lot of hay work. This series goes from 2750 thru 3250, if you want different hp. The chassis is common. You should be able to find these in the $13-15K range.
Thanks for the replies guys. Bought a 4430 at an auction today. More tractor than I need (125 PTO HP) but I got it at a heck of a price. They did have a 4020 there that actually went for more than this tractor.
   / need advice on older large JD tractor #5
Good job. The 4020 is a wonderful tractor, and it popular. The 4430 hasn't been "discovered" yet. Enjoy!
   / need advice on older large JD tractor #6
The Deere 4430s were a very popular tractor. I was actually going to suggest a 4430 for you before I came across your later post. If it doesn't quite fit your needs, you can always sell it and recover most of your money.
2004 20ft Explorer Pontoon Boat and Trailer (A51573)
2004 20ft Explorer...
1998 WELD-IT COMPANY FUEL TRANSPORT PUP TRAILER (A52472)
1998 WELD-IT...
KOOMEY INC VALVE ACTUATOR (A52472)
KOOMEY INC VALVE...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
