Need advise on wiring a OD Grinder
   / Need advise on wiring a OD Grinder #11
Ken, it doesn't get used much at all. Maybe 5 hours a year. We used to keep it clean but it gets forgotten, it's back near our welding area and catches a lot of grinding dust.
What type work does your shop do? Ken Sweet
   / Need advise on wiring a OD Grinder #13
We have 2 CNC mills, a Bridgeport & 2 CNC lathes, we do a lot of prototype work. 1 & 2 parts and do some quantity jobs but mostly prototype. That's what I like about it here always something different. Been here 21 years, I do all our mill work and all our welding.
I agree that having a variety makes the workplace a lot more enjoyable. I am curious about doing prototype work (1 or 2 pieces) on CNC machines. It seems there would be lots of time spent writing programs that may never be used again? Ken Sweet
   / Need advise on wiring a OD Grinder #15
I ran EZ Trak and Prototrak controlled mills and the programming is so quick and EZ. You can use smaller cutters to create contours and radii and the product looks better. The nice thing with CNC lathes is the constant surface speed and the ability it gives you for finish quality. You can program corner radii to eliminate stress points and also program it to break the corners (deburr).
   / Need advise on wiring a OD Grinder #16
Your mills 2 axis or 3 axis?
   / Need advise on wiring a OD Grinder #17
Those mills were 2 axis.
   / Need advise on wiring a OD Grinder #18
You job sounds almost exactly like mine. I do the same thing at an R&D facility except I'm the only one left for the last 3 years. I have a new trainee who has zero machining experience. I like your signature.
Yes, a lot of programming, setting up, fixturing for just a couple of pieces happens frequently. Part of the job. I tell the engineers the first piece is gonna cost them a lot. The 2nd is a bargain.
   / Need advise on wiring a OD Grinder #19
Ken, what do you do with your machines in your shop?
UNUSED IRANCH 14' BI-PARTING GATE (DAMAGED) (A57193)
UNUSED IRANCH 14'...
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
UNUSED IRANCH WROUGHT IRON SITE FENCE (A57193)
UNUSED IRANCH...
PALLET OF ALUMINUM PARTS (A57192)
PALLET OF ALUMINUM...
J and L Cargo Express Shadowmaster Enclosed Trailer (A55315)
J and L Cargo...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
