Need and education
   / Need and education #11
Pump says CCW so do not think it is reversable.
Then you will need a directional valve for Forward/Neutral/Reverse....I would go with an electric solenoid valve, and use a 3 position switch to choose F/N/R....speed will be by the pump lever, if one motor/tire/track slips, I would use brakes to transfer power to motor/tire/track with traction....
A variable flow divider would be another solution.....
   / Need and education #12
The pump could still be bi-directional. The CCW is the direction of rotation of the input shaft, but if the pump is bi-directional, then the flow can be reversed without reversing the directional of rotation of the input shaft.
suppose to be here tomorrow, so will see then, thank you all for your help
Genie GTH-644 (A50490)
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
